Question about GE WSXH208A Front Load Washer
My washer wont spin....
My tub on the washer is so so loose and it wont spin or ajitate.. I so new to this kinda of repair what do I do...... Ok Ive never fixed any thing
    President:
  • 1,294 Answers
Plug off the wall socket; open up behind the machine, your belt may have come off. Put it on back on the wheel, the belt should 'give' half an inch, if it is more, replace with new. While inserting the belt, it should first be fitted on the small wheel, then eased on to the bigger one, by turning by hand the big wheel
Posted on May 09, 2008
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
WASHER WONT DRAIN
Does the washer spin on rinse and drain cycles ok? If it does spin but won't drain, the problem is the plasic impeller in your drain pump. This model is a direct drive unit with a reversing motor that runs one direction for agitate, but reverses to spin the tub and operate the drain pump. So if it spins but DOES NOT drain, it's the drain pump, but if it doesn't spin or drain, than it's probably a lid switch. Also the tub to pump hose or pump discharge hoses may be clogged with something. If your mechanically apt, you can do this repair yourself and save a service charge. The pump runs about 30 dollars or so and is really easy to change out. Check out Youtube videos on Whirlpool washer repairs, they will show you everything to do. Yes, I said Whirlpool, because Roper is built by Whirlpool.
Hope this helps
kcomp1863
Dec 29, 2010 | Roper RAS6233KQ Top Load Washer
I have an old Moffat washer. agitator wont turn to wash my clothes. Cannot remove the ajitator. Took of the softener cup on top and there are four plastic, looks like screws but won't turn. Need advise on...
Hey there... Im working on my washing machine today also and I had the exact same problem. you just have to pull it upwards until it comes off... You have to kinda use your fingers and put them way at the bottom part of the agitator and pull up!..
Nov 13, 2010 | Washing Machines
Started normal cycle then gets to drain and spin clothes are still wet
Hello there:
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt, a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. then retry ok
Oct 07, 2010 | Whirlpool Washing Machines
H3 Elite washer.... steel tub is wobbling and cutting into the plastic ring liner. If steel tub or has separated from bearing, is this covered under warranty.... after 4 years.... or not. How expensive is...
rear pulley nut is loose. tighten . if it has been loose for a while pulley may be warped and also tub bearing and spin basket could be bad. dont have your specific model # to know if in warranty . can go to wpl .com and check warranty with your model # or kenmore then go to sears.com . i would use another servicer we waive are service fee if you fix the washer we only charge 65.00 service call. im sure you can find a servicer with a lower service call. thats the highest ive ever heard they will charge you double what anyone else charges.worse case scenerio could be 300-400 dollars if tub, pulley , spin basket need to be replaced. but i say its worth you replacing pulley or checking nut any other repairs for this i would just replace unit. again check your warranty i think the spin basket has a 10-20 yr warranty.
Sep 19, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem exist.no you would have to replace tub.i hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
The drum won't spin-
the drum wont spinn with wate in it(very fast anyway). if you remove the agitator, the inner tub lifts right out(its a floating basket) perhaps an article of clothes has gotten below it preventing free floating of the tub. While out ive als seen where the metal spline/shaft has worn down the plastic counterpart and the tub has nothing to grabonto to allw to spin, the sppline and plastic counterpart are very apparent after removing the agitator, they sell a spline repair kit(new spline and holder (3 screws) easy repair.
Oct 29, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer model series 23711 pn 10182371800
nurse annie give me your model number and approx age .and will be happy to advise mike give me the age of your washer as you might not have the same problem
Jan 14, 2008 | Washing Machines
Hi, check the drain pump clean the infeller and also check hose struck of linen build up .
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Wont spin after ive replaced the drain pump
Plug off the wall. Check to see if all the wires are securely in place, not just with the pump, but all. At the motor un-plug & replug.
Nov 29, 2007 | Zanussi F1245W Front Load Washer
GE WSXH208A Front Load Washer Logo
80 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
