Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Everthing is connected, no lights whatsoever. Was working fine until power outage this morning.
    Problem Solver:
  • 6 Answers
I would first make sure there is power to the outlet that your modem is connected to. If you already have something else on that outlet and it works, move on. Hook a light into the outlet to check - you may have tripped a breaker or blew a fuse to this outlet. If the outlet is OK, the surge during the outage may have destroyed the modem. You can take it to a repair shop or buy a new one. Any warranty will not cover the item. I suggest getting a surge protected outlet for all computer devices. Good ones are not cheap, but they come with insurance to pay for your devices should something happen.
Posted on Aug 28, 2010
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
Hi, this morning we experienced power outage in our location, after 5 hours later power came back, but not our main server IBM System x32002. I checked the monitor and there is power. I check the green...
Depending on what caused the power outage, you may need to replace the power supply in the server. When outage happen and the power is restore. a power surge can destroy power supplies, especially if not connected to an UPS unit.
Good Luck
C2Solutions
Feb 17, 2011 | IBM System x3200 M2 Server
Internet light does not light up - was working until an outage at the exchange. Outage nnow repaired but light not on and no connection.
If you're saying that the outage is now repaired what you can do is to power cycle the modem and wait until the internet light lit up. If not try to report it to your ISP so that they can investigate on it.
Thanks for using Fixya.
Feb 06, 2011 | Zoom X6 (5590) DSL Modem (55900003)
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rca d52w19 power but no picture...
Solder around flyback pinns this should fix it.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
113 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
