I bought a used Toshiba P35. I am having trouble with it either randomly shutting down and then restarting oe freezing up at different places on restart. I cannot get into the bios because it ask for a password which was installed by the previous owner who I do not know. Any suggestions on how to get around the password on the bios?? Thanks, Jim
  • amfriction Aug 29, 2010
    You are right. I cleaned the memory contacts and it quit shutting down. Thanks,
    Jim
    President:
  • 3,278 Answers
Hello.
Your laptop is overheating, caused most likely by dust or faulty memory or fan.
First, take all safety precautions: disconnect all cables, remove the battery and touch metal to dispel static electricity.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
If still a problem, remove all memory and insert one at a time and boot to test to see if one module is faulty.
Hope this helps.
Posted on Aug 28, 2010
  • NinaE Aug 30, 2010
    You are welcome, Jim. Thanks for using FixYa.
Toshiba Satelite shuts down randomly
Try reinstalling your windows, or the program you use.
Or, look if its overheating, buy a cooling pad, it's not really expensive and it helps alot.
Dec 28, 2012 | ASUS Computers & Internet
My toshiba laptop restarts randomly when it plugged.,and again restarts sometimes it will shut off .but no problem occurs when in batterry power.please help me to solve this problem.
Many models of Toshiba Satellite laptops have a capacitor called NEC/TOKIN Proadlizer which loses its capacitance with time and hence laptop freezes, shuts down or restarts when AC is plugged in. One needs to replace this cap as shown here:
http://gs138.photobucket.com/groups/q251/S1BXDWUERU/
Jun 09, 2011 | Toshiba Satellite Pro L300 Notebook
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
Random Shutdown
Toshiba's are notorious dust collectors, try blowing back through the air vents and some clever use of the vacuum cleaner on the intakes can bring it back to life. also check the RAM for dust and dirt on the pins and clean as required. USE ANTI-STATIC Precautions!
Feb 21, 2009 | Toshiba Satellite P30 P35 Series Notebook
Toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Feb 09, 2009 | Toshiba Satellite P15-S420 Notebook
Random shutdown Toshiba P30c
have you done a virus scan
then a windows update
after that i would do a disk defrag
do you have a lot of programs downloaded
Jan 19, 2009 | Toshiba Satellite P30 P35 Series Notebook
P35 Shuts down
Go into Toshiba Power Saver in Control Panel and set Processing Speed and Cooling Method to midrange. You will not have the problem anymore.
May 26, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba P30/P35 Power keeps shutting down
An overheating occured on the unit that why it's shut off when the high limit of temp. reaches.
Try to use a lap cooler, it may reduce an overheating to the unit,
Mar 06, 2008 | Toshiba Satellite P30 P35 Series Notebook
IBM T23 Freezes
have you tryed update on the bios ?
i had the same problem with a toshiba lap top
and a bios update solved it
Nov 04, 2007 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
