Question about Samsung HCL4715W 47" Rear Projection Television
No picture Sometime I can turn on the TV and it works fine and then again, I can turn it on and I get no picture just a white screen. I have sound but no picture. You can turn it off and back on several times and eventually you may get a picture. A repair man looked at it and it was of two boards that is bad in the back of the TV. DO you know which board and is it worth fixing?
  • 121 Answers
It has to be your signal board thats what the white screen indicates because the other board is a deflection board and if that was bad you would have a black screen. Yes its worth fixing but the board would run about $300.00 to $350.00 if you cant find one let me know and I can post a link where I believe they would have one
Posted on May 08, 2008
When I turn on the TV it goes to white fuzz then the regular picture flashes periodically. What's wrong?
sounds like bad ariel connection check that first, sometime water get in cable if its fine on dry days that's it.
Apr 04, 2015 | Televison & Video
No picture on screen
Is the TV under warranty? If it is don't muck around, contact them straight away as you have a electronic problem with your screen.
Before that make sure the yellow chord is in the visual port and red and white into sound. 2) If thats all good try an experiment, as you know the sound is good, use one of the sound cables to replace the yellow. Is there a picture now? If so replace chord, if not make contact to exchange for warranty.
Sep 02, 2012 | X2Gen MV32T8 32 in. LCD Television
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
Apr 08, 2011 | LG 42LC2D 42 in. LCD HDTV
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
My sd-582hd5 picture goes black
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
May 08, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
