Question about Pioneer VSX-29TX Receiver
I am having a problem with my Pioneer Elite VSX-20TX receiver. When I first turn it on there is intermient sound coming out. It will play for a couple of secons then stop. This happens for 3-5 minutes. After that, it is fine and works like it is brand new. I was talking to a friend who owned it before me and had the same problem. It was under warranty though when it happened to him. My question is, what is wrong and about how much will it be o fix? Also, is it dangerous for it to be doing this? I am wondering if it would be cheaper to have it fixed or just buy a new one?
  • 4,323 Answers
Hi
This is happening due to a RAM IC on the board on the main board of the receiver. To troubleshoot this issue you'll need to remove the top panel of the receiver. This IC is on the DSP board, but there are no new boards available online. For a while Pioneer was exchanging the receiver for a newer model.
You have to change the position of two surface mount zero-ohm resistors, and replace IC9374 with the EEPROM Pioneer supplies now.
IC Installation procedure---
If you're good it can be done with a standard iron and a small screwdriver.
Apply high quality solder liberally to both ends of the IC with soldering iron, a long tip placed horizontally along the pins is a great help. Alternately heat both ends of the IC, and make sure all pins are bridged
together well. Use the screwdriver to gently lift one end of the IC whilst heating the solder- only lift it enough that solder wick will fit beneath the pins. Wick all solder from the end you just lifted, then heat the other end and slide the IC out of the solder, wick up all remaining solder carefully. Then clean PCB with flux remover, and put your new IC on.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 28, 2010
Where can i find diagram for bad soldering for pioneer elite VSX-27TX stereo receiver?
You really should be an expert to do repairs on these recivers but if that is the case, you can get the maintenance manual here:
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-24_26_27_29_D908S_RRV2133.pdf
Jan 02, 2016 | Pioneer Audio Players & Recorders
My new receiver (pioneer vsx-44) worked last night when we hooked it up but does not work now. I have tried many different settings and made sure the speakers are on and not muted. I also turned it o
Possibilities: your source setting is wrong, your tape monitor switch (if it has one) is on, your speaker selector position is wrong. Do any lights come on?
Oct 04, 2014 | Pioneer Elite 7.2 Channel Network Black AV...
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
Pioneer Elite VSX-92TXH subwoofer pre out does not work
These receivers have a history of having broken connections on the subwoofer jack. Would have to go in for repairs.
Apr 09, 2013 | Pioneer Vsx-92txh Elite Home Theater A/v...
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
On my Pioneer receiver (model # vsx-9100tx) MCACC light keeps flashing and system will not power on. Please advise.
Hi the mcacc light keep's flashing and will not come on. Can you help with this thank you Lee
Dec 22, 2010 | Pioneer Elite VSX-9100TX Receiver
I have a Pioneer Elite VSX-05. When I turn it on
check in front of your receiver and check the button wheres say mute press that button and
see if work or buy universal remote.
Aug 17, 2009 | Audio Players & Recorders
Pioneer VSX-29TX Receiver Logo
81 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
