Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
Model GLD566 normal wsh and heated dry ledskeep blinging and every minute a small alarm goes off. I can't seem to reset it. help
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: dryer cycle
HI thanks for your question. your problem might be the venting behind the dryer pull away from the wall to un kink the vent hose. thanks the appliance doc please rate my answer. thanks.
Posted on Oct 09, 2008
Daniel S
  • 4323 Answers
SOURCE: After starting dishwasher to do
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Posted on Aug 20, 2010
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
I need the reset codes for my dishwasher. It gets stuck in demo mode at times. That's what the repair man said who came last time. My dishwasher is the Whirl Pool Quiet Partner I, Model Number...
Hi, this is the reset code: Push/Press 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
Wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later it will start working....
Jun 11, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool dishwasher ''clean'' light is blinking. The ''cancel'' button does not reset the cycle. We don't know how to wash/dry our dishes. We tried the diagnostics but...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 09, 2011 | Dishwashers
Whirlpool GU 2400 : "clean"
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
Daniel
May 05, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Will not cycle. clean light flashing 7 times and then goes out, and then flashes 7 times, and this is a constant sequence
Hi
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Mar 19, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kenmore Dishwasher model 665-13743k601 The clean light is flashing and will not reset. The dishwasher will not run.
Hi
Jan 25, 2011 | Kenmore Dishwashers
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Hi
Daniel
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Green light flashing and water does not seem to be circulating in Dishwasher
Press the following normal, heated dry, normal, heated dry, wait till the lights all come on and then off again, press cancel and wait 2 minutes. This should reset the control, if you get the same symptoms returning we need to dig deeper
Apr 23, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
When i turn dishwasher on it goes to 1 and just stays there.one time a tech reset my old one by pressing three of the buttons but i cant remmember which ones. its a queit partner 1v
Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry, Normal-Heated Dry.
OR (depending on the model)
Hi-Temp-Heat Dry, Hi Temp-Heat Dry, Hi Temp-Heat Dry.
Hope that work`s. Keep in mind there is a underlying problem to cause the "1" to appear in the display repeatedly, so this is only a short term cheat.
Good luck.
macmarkus :)
Dec 08, 2009 | Whirlpool Dishwashers
Kenmore 665 15899
To reset and run diagnosis on the model 15899100 Kenmore Dishwasher you need to press the following buttons on your front panel. Hi Temp, Air Dry, Hi temp, Air Dry. The sears service technician just left my house and used these codes to reset and run diag on my washer.
Hope this helps
Jan 05, 2009 | Kenmore 15899 Built-in Dishwasher
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
105 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
