My AC unit will not come on even after I adjust the temperature on the thermostat
  • 674 Answers
I'm assuming that this isn't a window unit. Correct me if this is not the case. Take the fan switch from auto to run. The indoor fan should come on regardless of the temperature setting. If it doesn't then the transformer could possibly be bad. Before you change any parts though, make sure the circuit breaker for the indoor unit is on. Let me know what you find and I can give you some more things to check.
Posted on Aug 29, 2010
Are there adjustments on the thermostat to control excessive temperature swings in the room.
are you talking room ac or vehicle ac
the room thermostat is adjusted by the remote control and is fixed to high and low parameters and cannot be altered
Hugh fluctuations in temperature can be from people leaving the door open for too long or not closing all the windows and doors
for a car ac it is preset
Dec 01, 2015 | Cars & Trucks
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
AC trouble
First make sure your filter and the metal fins behind it are clean. Also check that the drain in the pan below the unit is clear. If this does not help then it could be the thermostat sensor or even a problem with the circuit board. If it is a computer or electrical problem it will be cheaper to replace than to repair.
Jul 07, 2013 | Heating & Cooling
How to change a thermostat in a 1995 toyota avalon
Radiator Thermostat - It is at the other end of the lower rubber hose of the radiator where the hose itself terminates on the engine- it is called thermostat housing.
For Ac unit - if manual adjustment- just like and ordinary thermostat of the air conditioner it is the knob where you adjust the temperature.
If electronic/digital type need to change whole assembly.
Mar 01, 2011 | 1995 Toyota Avalon
How do I turn on the central heat in a kz jag rv
Turn on your propane and set thermostat to heat and adjust temperature. It should all start on it own, as long as plugged in or fully charged battery connected. If it doesn't fire up first few tries, shut off and try again as it may take a few times to purge propane . If no AC on unit and thermostat is for heat only, there may be a lever on bottom side of thermostat to push over for on, then set thermostat temperature. If any problems, get back to me and I'll walk you through it.
Feb 13, 2011 | Water Heaters
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
