Question about Dell Computers & Internet
Cannt get sound on speakers to work. tried upgrading all drivers and also checked speakers themselves nothing seems to work. It might also be noted if I try to adjust the volume on the screen from the lower right corner (next to time etc.) there is no icon to select. Also, if i look up the sound adjustment manually it is grayed out and I cannot select anything
  • Dell Master
  • 27,725 Answers
Try control panel sounds and audio devices, audio, make necessary adjustments there
good luck
Posted on Aug 29, 2010
I have the Peavey triflex ii I have power and sound in the subwoofer but nothing on the satellite speakers I get no sound o checked all fuses and they are good. Wires are also good
My recommendation would be to try the satellite speakers, each , by themselves, from another source, say another amplifier, with a cd player or mp3 player hooked up to the source to confirm the speakers themselves are indeed functioning. If you try this, and still have no sound from them, it is the speakers. If they work, then the amplifier section of the Triflex rig is not functioning. A lot of times, Peavey has had issues with the Power transformers going out in their amps. Might have happened. If the speakers don't function attached to another amp, then you may have a blown speaker/crossover/ or maybe an inline breaker or fuse in the speaker . You can remove the back panel of the speaker to check this. It would seem improbable for both to go out at the same time, so my thought would be a breaker on the amplifier section of the Triflex, or the amp itself.
May 01, 2014 | Audio Players & Recorders
Laptop speakers work for 5 minutes before making no sound
it sounds like a fault in the speakers themselves. It's most likely a physical fault as the computer seems to think that everything is working okay. do you have a different set of speakers to try and see if the same thing occurs?
Dec 02, 2013 | MSI Microstar CR640 PC Notebook
Hi, i just recently upgraded my OS from winXP to win7. However, after installing win7 i couldn't get any sound from my pc. Device manager says that the driver is working fine. I checked the settings of...
go to control panel then hardware and sound then go to manage my sound devices under that will find playback under that you will have to click on speakers(single click) and and then the configure option gets activated then you have the option to check the speaker functionality and also you can go to sound tab select a sound and click on test to check it
Oct 27, 2010 | Realtek Semiconductor Realtek High...
No sound on my laptop
For sound issue first thing you can do is, to connect an external speaker or headphones if you have one to check if its working on this notebook if its working then its an issue with your notebook speaker if not its software issue for which you can reinstall the drivers
note : do not forget to check the sound setting first
Aug 12, 2010 | HP Pavilion dv9000z Notebook
HP Pavillion HDX 9000 - No Sound from Speakers My external speakers arent working. I am getting sound when I plug in my headphones, but thats it.I have updated the driver several times, but that doesnt...
Dear sir ...
in fact your son is right so please try another speakers from anywhere and if it work so the old speakers needs to replacement .
thank you
Sep 22, 2009 | HP Pavilion dv9000z Notebook
Install cd for monsoon
What makes you think you need special drivers for your Monsoon speakers? Do other speakers work properly when hooked up to your PC? Borrow a pair from somebody else if you don't have any other speakers you can try, and check. If they don't work either, Monsoon drivers are not your problem. I'm not saying nobody ever needs drivers for speakers to work with a computer, but normally, drivers for the speakers are not the issue if you're not getting sound through them.
The sound card driver and sound settings in BIOS, sound settings in Windows and for the sound card, and physical issues about the way the speakers are hooked up or whether the speakers themselves are functional are much more common sources of trouble than drivers for the speakers.
Start your troubleshooting process with this webpage:
http://www.computerhope.com/issues/ch000034.htm
If that one doesn't seem to address your issue, try websearching for other options with a phrase such as: troubleshoot no sound PC speakers.
May 31, 2009 | Audio Players & Recorders
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
Speakers not recognised in Vista
hi!!!!
try to check the audio driver
maybe it is not compatible with vista??
or download the latest driver for your audio
Nov 04, 2008 | Logitech X-530 Computer Speakers
System test?
sounds like ye olden sound drivers are unhappy. or the sound card is taking early retirement. check drivers first..if you can't find out what sort of drivers you have, send me a note to pn4pm@yahoo.com and we'll arrange a shared screen session
Feb 18, 2008 | Dell WL6000 Computer Speakers
Computers & Internet Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
