Question about GE Ovens
My self cleaning oven lock was accidentally locked, how do I unlock it
  • 236 Answers
SOURCE: Oven Door Locked
is it locked in the up or down position?
Posted on Jun 04, 2007
watugot
  • 290 Answers
SOURCE: Kenmore oven locked after celf cleaning
Try putting it back into clean mode and and listen for the lock motor to start turning. If you can hear it, keep trying the door until it opens. Don't hold steady pressure on the latch, just pull a little then let off. After you get it open, hold in on the door switch and cancel the clean mode and it should go back to correct position.
If this doesn't work, you may have a failed door latch, control, temp sensor, or switch. Post back with the complete model number and I will look it up and see which latch assembly you have and see if we can get it unlocked manually.
Posted on Oct 21, 2007
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
Posted on Aug 31, 2008
SOURCE: Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Posted on Sep 22, 2008
  • 10865 Answers
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
How do I unlock the oven door? It appeared to automatically lock while baking.
Did you accidentally set it for self-clean? That will automatically lock the door.
Jul 03, 2013 | Ovens
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    The frigidaire oven was accidentally turned on to clean then it was off now it is locked what can be done to unlock it??
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    Sep 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Good luck with this!!
    Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
    The oven door won't open, and there is still food in it. We have a Whirlpool Super Capacity 465 Model, amd need assistance immediately.
    Hello. It is possible that the oven accidentally got turned to the self-clean function. Check to see. If it is set to self-clean, the door lock activated. In order to unlock the oven has to be taken off of self-clean and then it has to cool down to room temperature before it will unlock. Joe
    Apr 04, 2010 | Ovens
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire self cleaning oven MODEL PLCF398DCC
    you should be able to simply hold down the contro lock button for 3-5 secs, and it shoudl unlock for you
    Nov 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire gallery self cleaning convection oven
    Press and hold the "clean" button for 5 seconds.
    May 11, 2008 | Ovens
    Ovens Logo
    52 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
