Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer and it stop with 2 minintes on it and flashes a F
  • icatci Aug 31, 2010
    Hi dear.Would you let me know what is the exact code like:F14 or FdU,then I can help you with the issue.Thanks.
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 28, 2010
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet stopped during wash cycle.
UNPLUG THE WASHER AND TAKE THE 3 SCREWS THAT ARE ON THE BACK OF THE WASHER OUT AND REMOVE THE TOP PANEL OF THE WASHER. CAREFULLY UNPLUG AND REPLUG IN THE WIRING SO THAT U WONT GET THEM MIXED UP. DO ALL OF THEM, FIRMLY BUT GENTLY. THEN HOLD IN THE SIGNAL CYLCE LITE FOR 3 SECONDS. TRY TO RUN A LOAD AND SEE IF THAT WORKS. IT DID FOR US, SO FAR SO GOOD. GOOD LUCK!!
May 30, 2009 | Whirlpool Washing Machines
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer control panel flashing and won't restart
I don't know if this is a real solution but it wokred for me. I just unplugged it for about 10 minutes and then plugged it back in. The flashing stopped and I was then able to resume normal function.
Feb 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
