Question about Dell OPTIPLEX 745 PC Desktop
I powered off my Dell Optiplex 745 as normal one night before bed. The next morning I went to turn it on and it just displayed a yellow flashing light where it normally displays a green light. The fan did not turn on or anything just a yellow flashing light. I held down the power button and the yellow light stopped, I then pressed the power button again and it just did the same thing... Does anyone know what this problem could possibly be?
  • Dell Master
  • 1,684 Answers
This model has been having problems with the motherboard that can cause that exact problem, Not powering up, Flashing yellow light or locking up right after booting up. The first thing to check is parts called capacitors on the motherboard. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/ that has detailed pictures and information about this issue. The pictures are of the tower case Optilpex 745 but the board is the same for your unit. Check it out and see if your board has this issue. If you can solder then you should be able to fix it yourself for less than $15.00 If your board does not have the bad capacitors then the blinking yellow light is a failure in the power supply unit.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Sep 15, 2010
    Filmmaker:
    Uploaded 5 video answers.
  • 30 Answers
OK first of all how did you power off this computer?
Posted on Aug 28, 2010
Hello i have a Dell Optiplex 745 it boots up and starts windows 7 normally then the the screen goes black does anyone know how to fix it?
Can you boot into Safe mode. It is usually done by pressing a specific key during the POST session. If you can, then boot into safe mode and delete the Video Driver. Reboot. TYou should have a VGA display, download and install the video driver again.
Feb 05, 2015 | Dell OPTIPLEX 745 PC Desktop
Where is the fuse located optiplex 745
I would suggest reading this service guide for the Dell optiplex 745 to find out the problem solution. There are several fuses in the unit and problem could be in power supply.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-745c_User's%20Guide_en-us.pdf
Apr 27, 2014 | Dell OptiPlex Computers & Internet
Yellow light power button
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jun 10, 2013 | Dell OPTIPLEX 745 PC Desktop
your PC is in power saving -mode.to change go to control-panel
Energy and Power settings.and adjust the profile of the computer.
I have a dell optiplex 745 and the light on the power button flashes orange when power is connected
IS YOU SURE IT'S THE POWERBUTTUN.AND NOT THE HDD BUTTON .IT SHOULD FLASH WHEN THE COMPUTER READ.?
Apr 04, 2013 | Dell OPTIPLEX 745 PC Desktop
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
My GX520 was shut down as usual last night...I turned on this morning and I get nothing...just a little yellow/amber light blinking where it is normally green....help
Here is the info straight from Dell. looks like you have an internal power issue. You will most likely need to contact Dell directly for assistance, they are pretty good about giving support even if the system is no longer covered under warranty.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Dec 28, 2010 | Dell OptiPlex GX520 PC Desktop
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell OPTIPLEX 745 PC Desktop Logo
979 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
