Our Frigidaire front load washer will not start. The door open buzzer just buzzes even though the door is shut.
  • onewaybooksp Aug 30, 2010
    I am trying to get information on a FRONT LOAD Frigidaire the last info was all about top loading washers. The problem is with the door. It does not sense that the door is shut so it will not turn on. Is it possible to "hot wire" bypass this switch so the machine will think the door is shut and therefore run?
  • onewaybooksp Aug 31, 2010
    I can not see how to rank a solution. The "solution" was not at all helpful. It seems that the "expert" did not even read my problem since they gave generic info about a top loading washer and I clearly asked about a front loader.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link regarding your query…
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntworkatall
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 28, 2010
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Our Frigidaire front load washer
This is usually caused by the door switch. These are fairly inexpensive and very easy to replace. First unplug your machine. To check you will need to remove the wire ring that holds the front door seal to the front panel. To do this go to the six o
Posted on Sep 08, 2010
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
www.shopyourway.com > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Sep 08, 2010 | Washing Machines
Washer won't lock door to operate
I have the same problem. My door buzzer alarm keeps buzzing and won't lock. Seems like I may have a faulty switch or latch. Did you ever get yours fixed?
May 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My Frigidaire front load washer won't start it doesn't even fill up with water and it also doesn't spin.
Most likely a faulty door switch. Machine thinks door is open and won't start. Part number 131763202
Apr 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock buzzing
sounds as if your door lock is broken and needs to be replaced.
Feb 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
Jul 30, 2008 | Washing Machines
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
