Question about HP Computers & Internet
The screen not show noting when pc notebook turn on.
    Scholar:
  • 156 Answers
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Posted on Aug 29, 2010
My Acer Aspire one NB214 is not showing any posts to the screen when i turn it on , its just the Led for power whichi is showing.What could be the problem?
A loose connection some-where, or a failed screen or inverter.
Try connecting this Notebook to another screen. If it then works it confirms that the laptop screen is faulty.
Thanks
damnor01
Apr 11, 2011 | Acer Aspire One PC Notebook
NOTE BOOK SCREEN DOES NOT COME ON
Screen does not come ON or not showing any display even the power LED is lit. Sometimes it is due to the laptop was not shutdown properly or the battery was drained or laptop was left idle. This is a simple solution that may fix the problem. If the power LED is lit, turn off the NB, remove all the power sources (battery and charger). Without the power sources, hold the power button for 10 secs and put the power sources back and turn ON the laptop. If this doesn't resolve the problem, it needs to be checked for possible Motherboard problem.
Hope it works!
Mar 12, 2011 | Acer Aspire One PC Notebook
My Sony Vaio VGN FS630W turns on but noting shows on screen and looks like the hard drive is not loading. What should i do?
Your problem can be either a problem with the LCD connection or the laptop's suspend feature. Try this:
1. Close the LCD then open it again. Wait a few seconds and the screen should light back up if it is only a problem with the suspend feature.
2. If the above does not happen, do a hard shutdown by pressing on the power button for around 5 seconds. After it shuts down, turn it on again and the screen should light back up.
If the above does not work, seems you may need to have your laptop serviced.
NOTE: Please rate our help to keep this free service online.
Jan 09, 2010 | Sony VAIO VGN-FS630/W Notebook
Bios chip location on mother board
no,, reinstalll the vista,, the problem will not occur again
Jan 08, 2010 | HP Compaq Presario V2000 Notebook
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
New lcd screen for p30/35 is showing very dark?
check the settings in :
start...control panel... toshiba power saver.
see the disply brightness and drag the rule for the wish point for you.
also the same setting can be done when you press Fn+F7
note that FN is a button in the keyboard located between ctrl and alt.
hope it helps .
Nov 25, 2008 | Toshiba Satellite P30 P35 Series Notebook
I have a Gateway mx3422 notebook. I cannot get the display to clone when I hook it up to a projector. The notebook screen goes black and the display shows on the projection screen.
hi!!!
there is a setting in your desktop
try go into control panel
then click on display then go to
settings and the
advance try locate the dual monitor settings
Oct 31, 2008 | Computers & Internet
Desktop scree showing white bright spots
The bright spots which you are seeing my be the failed pixels on the screen.
Once connect the external monitor to the notebook and check the display on the external display.
If you don't have external monitor, then restart the notebook and Press F10 or F2 key to Enter into BIOS. If the screen is same with bright pixels in the BIOS screen, then the it is confirmed the issues is with bad pixels.
If your notebook is under warranty, then HP will arrange for mail-in.
Note: There is Pixel policy from HP, go through thebelow URL:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00288895
Aug 03, 2008 | HP Compaq Presario v3000z Notebook
Won't boot properly or show anything on the screen
Power surge and your adapter is not compatible with that note-book
Jul 28, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
