The fan for my heat/a/c is not working how do i check to see if the fan is bad
  • 43,501 Answers
Take a voltage meter and check to see if it is getting power to it when it should be running...no power look somewhere else... if tou have power the motor is toast...
heatman101
Posted on Aug 28, 2010
My 2007 dodge nitro 3.7 only over heats when idle..is it that I have a bad radiator
No rad fine check the fan is working ,either the fan motor ?? connection to the fan motor ?? fuse ?? relay?? or temperature sensor?? any one of these will cause the fault
Jul 31, 2015 | Dodge Cars & Trucks
Ford f150 xlt, blower fan won't blow ac into cab of truck can feel cold air when on highway. But fan not working. Help?
Check to see if the blower works with the heater on. Turn the control to heat and see if the fan works. First check the fuse for the blower. If the fuse is good and the blower does not work with heat on , the blower may be bad or the speed resistor maybe bad.
May 21, 2014 | Cars & Trucks
Ac fan not working, ac is cold but fan won't blow air into cab...
check the fan itself to see if it works. check the heater fuse first! if all is ok, you probably have a bad heater fan resistor. to check blower, please go here on pc for info on blower. .cargurus.com/Cars/Discussion-t16272_ds569146
Car over heating was losing coolant now is not but is still overheat already replace thermostat but that didnt fix the problem
is the fan working??? it's possible the fan relay is bad if it's not coming on. may just be a bad fan motor. once it heats up the fan should kick on. check it and see.
Apr 23, 2011 | 1994 Toyota Camry
I have a 1993 geo storm. The heat goes on and off when it wants to. It works when u start the car in the morning then it may not work the rest of the day.
if the fan is not blowing its probably bad connection at the motor remove fan cover check connection. No heat check coolant level.maybe thermostats bad, faulty radiator or water pump
Jan 12, 2011 | 1993 Geo Storm
OVER HEATS
Fill over flow bottle right to the top and run engine....watch for bubbles.
If you see bubbles you may have a bad head gasket or a possibly a cracked head.
This allows combustion gases into the cooling system and the system just can't dump that amount of added heat.
Aug 19, 2009 | 1999 Chevrolet Malibu
This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is...
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Jul 21, 2009 | Heating & Cooling
What reasons other than fuses would make the heat and A/C stop working. The fan will not come on.
Thermostat, blower motor, system needs a recharge, a short, a loose ground, dead battery, vehicle not turned on, no heat or air installed in vehicle - option not selected -, bad modules, other fuses bad - you'd be surprised how much of a difference it makes checking ALL fuses and replacing bad ones, bad control, system needs replaced, heat not turned on, air not turned on, bad fan. bad fan motor. A million reasons, so at some point, you may need to get it to looked at.
Jan 24, 2009 | 1995 Isuzu Rodeo
I have an amana package system heat pump model number phb30c02e , sometimes the indoor blower will not kick on thus making no air come in the home at all throught the vents, i tried a new copasitor and ...
Sometimes the thermostat can have a burnt place in the fan contacts. This stops the interior fan motor because the compressor wiring is not interconnected to the interior fan. The compressor command is the yellow wire. The interior fan command arrives from the thermostat on the green wire. Check the green wire for delivering 24 volts AC to the fan relay.
During heat, the heat is electrically interconnected with the interior fan. Thus, if the thermostat is bad, the fan will work properly during heating. I know July is a bad time to turn the heat on, but this is a method to see if the interior fan works properly and is not getting the proper command during cooling.
Jul 24, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
