Question about Dryers
When drying I hear a sound like a loose fan belt? What can I do to check to see if the belt is loose?
    President:
  • 3,074 Answers
You will have to disassembly the front panel of the dryer and check you drom belt and rollers. Unplug machine open door remove screws and with a screw drive gently pry up on each top corner. Good Luck Tim
Posted on Aug 28, 2010
I have been hearing a cricket like noise ! 1995 v10 . Today thing got louder . Sounds like it could be the fan clutch.I checked the pulleys they all seem good . How do you check the fan clutch ?
When you said you checked the pulleys, did you take the belt off so you could spin them? To check for rough or loose/side play/wobble in the bearings. While the belt is off the tensioner make sure the tensioner has full and free movement. Buy a can of belt dressing, see if that makes the chirpping go away. It does on my 05 trailblazer, for a few days. I think my belt is bad, in that it tracks back and forth on the smooth back pulley while the engine is running.
Feb 22, 2017 | Cars & Trucks
I have a Whirlpoll estate dryer It makes a hi pitch sound How do i fix it
There is a belt that surrounds and drives the drying cylinder, or drum, made of similar material as a fan belt in an automobile, except much thinner material, and it encircles the drum. It surrounds the drum, goes thru a smaller motor/roller set and back around again. There is a spray that's used on auto belts to prevent slippage, called "fan belt lubricant" or similar name. It can be sprayed onto the belt thru holes in the rear panel, or if possible, from UNDER the chassis. It is possible to lift the dryer and tilt it backwards, but applying the spray from the rear is easier in some cases. The belt, or small roller assembly is probably the source of the high pitch sound. The tumbler or cylinder, spins on a single spindle but rarely needs lubricating. These parts are the only moving parts, therefore, the only bits of machinery that might cause the high-pitched sound you hear.
Sep 21, 2014 | Dryers
Squeaking fan belt
I had a book written for you and remembered something basic I learned in electronics school and had to delete it all. Sigh. So with a smile I start all over and hopefully make this short.
Are you certain there is a belt?
Let's assume there is. A belt means a motor is spinning the belt which is spinning another pulley or "wheel". You could be correct that the belt needs to be changed. They stretch over time causing slippage. That is one way you hear "squeak". The other way which I hate and am dealing with on my car right now is the pulley or pulley's themselves.
If you don't have a belt then your motor is directly running your fan. That means the "squeal" is coming from the pulley's bearings. Most fans I have seen come pre greased from the manufacturer and are not made with a hole to squirt a little inside. They are designed with an expected lifespan. That's another story though.
The bearings get too dry and they begin to, well, drag. That drag is the squeal you hear. Your warning sign that pretty soon they are going to stop dragging and just dry up and stop rolling completely. When that happens you may turn your fan on and hear a hum but the fan doesn't work. To simplify this for everyone, the ball bearings inside no longer roll so the fan no longer spins.
You may have a belt and two pulley's (or more like in a car) and have a good belt but a bad pulley. Most people throw away the product thinking it is no longer useable when all that is needed is to loosen a single screw in the middle of the pulley and replacing it with it's exact make giving the device another jillion years of use.
Now for the conclusion. If you find that the pulley is the problem, go ahead and change that belt that has never been changed to save yourself from the squeal you will hear from that new strong pulley making that loose belt squeal.
One last thing. Check by seeing if it wobbles when turned on or feels loose and slightly wobbly when turned by hand, with it turned off of course. Good luck.
Jan 05, 2014 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Loose fan belt
It can be worn out fan belt or the fan is got dried up and needs lubrication.Inspect fan belt.
Check the help link mentioned below:----
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Dec 09, 2012 | 2007 Chevrolet Kalos 1.2
2005 hyundai accent serpentine belt or fan belt?
It could be the belt or the A/C bearing might be going out. The way to check to see if the A/C belt is loose is to push down on the belt if you can push it more than a 1/2 inch - loose belt if not it may be something else like the A/C bearing. I always say expect the worse and hope for the best. So, I hope you are correct on the belt being loose.
Feb 28, 2017 | 2005 Hyundai Accent GT
Noisey sounds from under the hood when starting car
If it is a rattling sound the starter may be loose, the starter bendix gear might be damaged.
If it sounds like a fan, it is likely the cooling fan.
If it is squealing, it is the serpentine belt. The idlers may be worn, their bearings may be dry- they make a chirping sound at slower speeds when they are dried out. Replacement is the best option.
Air pumps can sometimes make a thumping sound, and if certain emissions valving rusts through, it can be outright exhaust noise.
If it is a high pitch whine, that is usually the alternator. It is not a good sign when they begin to whine. Alternator bearings can also fail, and the sound varies.
Water pumps and fan clutches can also fail and they tend to make softer sounds. These can be checked by checking for radial play in each item with and without serpentine belt tension applied.
Jan 18, 2012 | Cars & Trucks
How to Troubleshoot a Ford Explorer?
for a vacuum leak spray around with wd 40 the engine will speed up if a leak is found , remove the fan belt and spin the pulley replace if noisy , a fan belt will often make a clicking noise , start the motor with the belts off to check.
Apr 13, 2017 | 2003 Ford Explorer
My jeep has stayed in a covered garaj for 8 months, but I have taken it to the dealer to be tuned it had a whining sound they said that the pistons were clogged from staying, labor+tax+parts had cost me...
The problem could be simply drying up of grease of the fan & water pump combined with a loose fan belt. I would advice you to grease these parts including the dynamo and check the belt tightness.
May 03, 2011 | 1995 Jeep Grand Cherokee
For past 6 months dryer has been making a noise while drying and when I turn it off sounds like it is still spinning for a second. Now dryer is making a squealing noise as well and not drying the clothes...
Sounds like the blower wheel (fan ) is loose on the motor shaft.... that is the spinning you are hearing...
but the fan/blower is not running full speed so it is not moving enough air...
heatman101
Jan 18, 2011 | GE DBXR463EDWW Electric Dryer
Fan belt squeaking
If you check tension. If it is loose ..over 1/2" freeplay it is too loose. Tighten. If it feels tight. Then the belt is likely dried out and needs to be replaced... Check tensioner to be sure nothing is froze up. Like water pump or tensioner pulley. Check other belts as well.
Dec 25, 2010 | 2002 Chevrolet Silverado 1500
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
