Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Modified Lever Assembly
Where can I get the Modified lever assembly?
Sears Kenmore
Model: (106) 505 22 101
Serial: SM 205 5139
my email is efzurek@yahoo.com
  • jkashmore Sep 03, 2008
    is there a modified lever assy for a GE TFX25VRBA side by side frig?
    Genius:
  • 1,073 Answers
Whitch lever assy are you talking about
Posted on May 11, 2008
My lawn mower model 425613x8a only drives in reverse what is my problem and how do I fix it?
I'am not to familiar,with this model number,of this tractor. But i do know that there is a safety switch,installed below the shift lever. Usually this switch,controls the neural,forward and reverse for your tractor. I suspect the forward motion contact is bad in the switch itself. You will have to remove the motion drive assembly and purchase a new switch,sometimes the safety switch is part of the whole assembly. You can find this assembly,under the shifting lever under the tractor,s floor. It could be on the right side or the left side depending on the location of the shifting lever.Sincerely,Brad Locke DTD 12/03/15
Sep 07, 2013 | Sears Garden
The 4 wheel drive shifter is broken. How does the linkage to the transfer case come apart?
Shift Lever NOTE: Remove the shift ball only if the shift ball, boot or lever (7E067) is being replaced.
Removal
  1. Raise vehicle on hoist and position suitable safety stands under vehicle.
  1. Prior to removing the control lever assembly (7E069), be sure the shifter is in the 2H position.
  1. Loosen (do not remove) the nut retaining the shift handle (7E067) to the control lever assembly (7E069). Remove the shift handle (7E067) from the control lever assembly (7E069).
  1. Remove the vent hose (7D494) from the notch in the detent plate.
  1. Remove the control rod (7A315) from the control lever assembly (7E069). ani_caut.gif CAUTION: When removing the control rod (7A315) off the control lever assembly (7E069), do so very gently so as not to damage the control lever assembly.
  1. Loosen (do not remove) the large pivot bolt holding the control lever assembly (7E069) to the detent plate.
  1. Swing the control lever assembly (7E069) out of the way and remove the two bolts (39129-S2) retaining the detent plate to the transmission extension housing. Remove the entire control lever assembly from the vehicle.
Installation
  1. Prior to installing the control lever assembly, be sure the transfer case link (7B106) is in the 2H position (pointing upward).
  1. Install the two bolts (39129-S2) to retain the control lever assembly (7E069) to the transmission extension housing and tighten to 92-125 Nm (68-92 ft-lb). Refer to the following illustration for bolt hole application.
  1. Attach the control rod (7A315) to the control lever assembly (7E069).
  1. Tighten the large pivot bolt to 92-125 Nm (68-92 ft-lb).
  1. Attach the vent hose (7D494) into the notch in the detent plate so the white mark is flush to the outside surface of the plate.
  1. Install the shift handle (7E067) into the control lever assembly (7E069). Tighten the retaining nut to 27-38 Nm (20-28 ft-lb).
  1. Check transfer case for proper shifting and operation.
Feb 27, 2010 | 1992 Ford F250
Kenmore 97478100 dryer will not start (not a heating issue)
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Oct 08, 2009 | Kenmore Dryers
Dryer just stopped
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
My Kenmore 90 series just quit.
Check the following areas to address this issue.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer/control
Jun 17, 2009 | Kenmore Dryers
My kenmore 70 stop working wont enen start
Check the following to address this issue.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 11, 2009 | Kenmore 63942 Dryer
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
3. Thermal fuse
4. Timer/control
May 31, 2009 | Kenmore Dryers
Dryer doesn't turn on
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
3. Thermal fuse
4. Timer
Nov 13, 2008 | Kenmore 659 Electric Dryer
Dryer won't start due to delay button lights up and won't go off
3. Thermal fuse
4. Timer
Nov 09, 2008 | Kenmore 659 Electric Dryer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
269 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
