Question about Hoover Vacuums
Burshes will not spin, filter is clean - Hoover Vacuums
  • 377 Answers
Drive belt missing or not properly installed on motor or brush/beater? Perhaps foreign matter caught in ends of beater brush that are holding the brush tightly in place. Clean the debris away and hit with a little WD40, but not much. Make sure it turns freely by hand prior to putting it back into place. If the belt is loose, make sure it is replaced with the proper belt and installed correctly.
Posted on Aug 29, 2010
2 Suggested Answers
SOURCE: Brushes don't turn
I Had the same problem, The brushes are operated by water pressure. Under the machine were the brushes are is a white peice of plastic pull this out and try cleaning the screen. I found this when I removed the cover and lubricated the gears at the brushes, If that does nto work you will have to remove the turbines and lubricate.
Posted on Dec 30, 2008
Dyson canister DC39 - beater bar won't spin once it touches the floor
Some models have the beater bar driven by the airflow from the vacuum rather than a small motor. It takes a lot of suction to turn the brush roll. Make sure there are no restrictions which will reduce the airflow and suction. Replacing the filters may help if the vacuum motor still has adequate suction.
Sep 17, 2017 | Dyson Vacuums
My problem is that dust is shooting out of my powerforce bagless bissell. I pulled and detached the filters, hitting them againt my front steps which is cement, burshing my hand across the filter . Yes...
It could be a clog somewhere, a air leak somewhere and/or clogged filters. Cleaning filters does not necessarily mean they are not clogged. They should still be replaced quite frequently.
Sep 06, 2017 | Bissell 6594 PowerForce Bagless Upright...
Hepa filter does not turn on hoover wind tunnel vacuum model U6630900. It was working (turning) and I cleaned the filter and canister and now it no longer spins when the vacuum is running.
The part you refer to is not the HEPA filter. It's a very common misconception that that part spins - it looks like it when there's dust whirling around it. In fact, it does not spin - there are no visible moving parts.
Jan 07, 2010 | Hoover U6630-900 WindTunnel Bagless...
Cyclone will not spin
Even thought the belt may look fine the belt still can be worn and therefore no turn the brush or the clutch. The belts you need are these here:
DC07 with clutch belts
DC07 without clutch belts
Nov 08, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes on the unit do not spin.
try to clean the filter under the machine or the filter behind the clear plastic, were you see the hypnotic disc sprin that lets you know that the brushes are spinning. To remove : the plastic piece that looks like a triangle, ( were the indicator is that lets you know the brushes are turning ) remove by pulling from top, clean lent from screen and reverse your steps to put back on.
Jul 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes don't turn
Dec 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Thr brushes are not spinning and it smells
That is your belt burning, turn the vacuum upside down and make sure your brush is spinning freely. Something may be wedged in your brush.
Dec 27, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Clogged hepa filter
If the hepa filter is clogged chances are it is not turning like it is supposed to. Hoover apperantly has a terrible R&D department because this is a bad unit. The filter is supposed to be self cleaning because it spins and a little tab is supposed to knock out dirt but does a crappy job of that. The transmission is what spins the filter and this must be replaced. If in warranty take it to your local Best Buy for service.
Dec 15, 2008 | Hoover U8361-900 WindTunnel 2 Bagless...
Roller wont spin
is there hair, strings, twine wrapped around the roller? perhaps this is the issue, is there still suction by the rollers or has this stopped as well?
Jun 12, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
41 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
