Computer gateway 700 xl
GATEWAY 700 XL DESKTOP, I BOUGHT A NEW POWER SUPPLY
IT POWERS ON AND THEN IT STOPS, IT WILL NOT ACTIVATE THE HARDDRIVE OR ANYTHING, WHAT COULD BE THE PROBLEM.
MR WILLIAM HARRIS
wl.harris@yahoo.com
Shaggyrat - idiot - 700XL is not a laptop thus no battery
Posted on Dec 02, 2009
    Genius:
  • 1,224 Answers
Battery to plug switch is not set to except power to plug so battery can charge right now it still thinks its on the battery so no juice no comp
Posted on May 07, 2008
Gateway dx300 hard drive
Gateway DX300 Desktop PC is a series.
Could be a Gateway DX300MC, or DX300QS, or DX300S, or DX300X,
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=DX300series.html
Fortunately all models in the series use a SATA harddrive.
[ Gateway DX300X Desktop PC used as an example,
http://support.gateway.com/s/PC/DX300/1008555/1008555nv.shtml
In the list click on - Components
On this page scroll down to the bold subheading - Harddrives
All models came with a Western Digital harddrive, but it doesn't matter what the harddrive manufacturer is, that you use ]
What size in GB amount? Depends on what you want. I myself wouldn't go more than 320GB.
That is because your anti-virus program has to sift through the harddrive.
The larger the harddrive, the longer it takes.
For more capacity, I would install a 1TB harddrive into an external enclosure, and use it connected to the computer, with it's USB cable.
(It will also come with an additional external power supply)
But that is just me.
Bear in mind that a new harddrive has no Operating System on it.
You have to purchase a genuine copy of Windows, and install it.
(This is if your harddrive presently on that Gateway is bad)
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
Regards,
joecoolvette
May 20, 2012 | Gateway 310S (2900621) PC Desktop
Why won't my gateway 700 s boot from cd
You need to open your from its BIOS page. The way you can do this is to restart it and once it starts up press the delete button repeatly until your BIOS page comes up.. From here you have to change what your comptuer boots from. Change it to boot from CD DVD rom first then the harddrive. once you have this done save and quit the bios and pop in your cd.
Jun 11, 2010 | Gateway 700 XL PC Desktop
My gateway 500xl won't power on
The first thing I would try is connecting a new power supply. If you can borrow one from a friend/neighbor/family member/whatever that would be the easiest/cheapest thing to try first. Also make sure all the wires are connected to the right places and securely connected.
Jun 04, 2010 | Gateway 500 XL PC Desktop
No power
Could be you power supply... try one from another machine.
Apr 04, 2009 | Gateway 3250S PC Desktop
I have a Gateway 510xl and would like to upgrade the power supply
Changing out power supplies is not that difficult task. Upgrading to a 550 Watt power supply would be a good idea because it will give you more power than you need at the moment. You can google the power supply with the word problems with it and see what comes up. The main thing to be sure of when selecting a new power supply is to make sure that you get one with the appropriate connectors for your hard drive, motherboard and processor. For example if you have a SATA Hard drive then you will need a PSU that has SATA power connectors. Most newer power supplies (PSU) have these. The box should list what connectors it has.
Mar 12, 2009 | Gateway 510 XL Peak Performance (510XLPP)...
No power
Did the service tech actually look at the computer? I don't know how anyone could make this diagnosis without doing some testing. It could be the motherboard but it could be something else too. I would first suspect the power supply. They frequently go bad. Test that.
Jan 02, 2009 | Gateway 3200XL PC Desktop
Gateway 700XL, yellow light only when power is pushed on.
You are on the right track. First, swap out the power supply. That normally is the issue. If that's not the issue, verify that the power switch indeed is working. You can do that by determining which color wires are for the power switch, then hold a multimeter set to resistance on the ends of those two wires. When the button is pressed, it should go to zero. If not, then the switch is fautly. That is an unlikely scenario, however. If the new power supply fails to work and the switch is okay then the problem is the motherboard.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | Gateway 700 XL (700XLDFM) PC Desktop
My gateway 700 xl doesnt boot
Unplug the power from you 700xl and from you monitor. Try removing the cmos battery and reinstalling it. Then, plug everything back in and try restarting. If it continues to give you the yellow light, you may need to replace the CMOS battery, especially if it is more than two years old.
Another thing to consider is if your power supply is underpowered for the number of external devices you have plugged into it (i.e., cd, dvd, external hard drives, printers, pci cards, etc). Gateway installed very low powered power supplies in their 700xl desktop computers. Usually only around 250 watts maximum.
If you are replacing the power supply with another 250 watt maximum power supply, and you have a lot of external devices plugged in, you may need at least a 350 watt power supply....if your CMOS battery is not the problem.
Nov 06, 2008 | Gateway 700 XL PC Desktop
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
