Question about OKI MICROLINE 320 Turbo Matrix Printer
Okidata ML 320 turbo printing problem
I just replace the computer this printer was attached to, an old IBM running believe it or not windows 98, with a newer xp box i am using an old access data base, when i tested all that came out was mumbo jumbo, i need to know if there is a way to configure to be able to print my invoices correctly.;
  • 42 Answers
Change driver!!!
Posted on May 07, 2008
We had a computer crash that required replacing the computer we had with one running Windows XP w/SerPk 3. We are still using the okidata microline 320 turbo that we used with the old computer. We are a...
The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available.
If the driver did not work, try to use the IBM Proprinter or Epson LQ driver.
Mar 16, 2011 | Matrix Okidata Microline 320 Printer
Printer will not print in windows xp
This is form OkiData's support site; The link will take to where I found this information.
Support Okidata
Hope this helps and GOOD LUCK!
  • Description: ecblank.gif ecblank.gif ecblank.gif
    ecblank.gif The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available. Follow the instructions below to correctly install your printer.
    NOTES:
    Select "Oki Data ML 320 Turbo/D (IBM)" from the XP CD.
    The ML390/1 Turbo Printers are not on the current XP CD. Please use the IBM Proprinter or Epson LQ driver for these models.
    The driver should automatically install once the printer is connected to the computer and powered on. If it does not automatically install, then do the following:
    1. Click Start, then Control Panel.
    2. Click Printers and Other Hardware or Printers and Faxes.
    3. Verify that the printer icon is not already installed
    4. Click Start, Turn Off Computer, then Turn Off to shut down the computer.
    5. Connect the data cable either USB or parallel. If it is not then continue to step 5.
    6. Turn on the printer.
    7. Turn on the computer.
    8. The printer will now be automatically detected
Nov 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Lines on doc wont print
you got a driver for this very rare printer now?
What you give her IBM proprinter II protocol?
Should be a Proprinter III type
Go download here:
http://my.okidata.com/PP-ML320Turbo.nsf?opendatabase
Don't forget my four stars ;)
May 05, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Printing from 1989 DOS program "Labels Unlimited" with same
sound like a parallel connection.
Try this:
open a dos command prompt and type this command:
dir>lpt1
this would try to print through the dos mode if you connections is good it should print something.
Mar 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
I want oki ml 320 turbo driver.. eny body can help me on that..?? pls,,,,,
the oki data ml 320 driver should be bundle with the operating system. If not you can download it from okidata website.
http://okidata.com/mkt/html/nf/Drivers.html
Try it and let me know if this helps.
Thank you.
Mar 04, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 320 turbo
Your Oki model does not need drivers, for they are already contained since Windows 98 and up. However, if it still doesn't work, check that the printer emulation is set to IBM and then install a new printer using the IBM Proprinter II/III driver, also contained in Windows.
Be blessed.
Oct 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing jibberish
Hello babytenbucks,
I can help you setup your Okidata 320 printer.
Connect the printer to the printer port coming off the motherboard. Usually it's colored pink. Also known as LPT1.
If your operating system is Win XP do this. Open Control panel, open Printer & Faxes. Click File, Add new printer.
Uncheck, automatically detect & install my plug & play printer.
Click Next. Allow it to use LPT1. Click next.
There are two windows here. On the left is Manufacture on the right is Printers. Scroll through Manufacture till you find
Okidata. Under Printer, scroll down till you see Okidata ML 320 Turbo/D (IBM), click next. You can give it a new name or leave it as is. Make the 320 the default printer. You can let it print a test page. Either way re-start the system. Try another test page.
Click the link below for a .pdf file which is the manual for your
Okidata 320 Turbo.
http://www.precision.com/manuals/Okidata_ML320_321_Manual.pdf
If you do not have Adobe's pdf reader download it from the next link.
http://adobe-reader.download-express.org/now/
babytenbucks, if your still have any trouble please just post back & we'll get it solved.
Good day!
& please vote...
Feb 25, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki ML 320 Turbo/D IBM - JetDirect 170x Print Server prolems
Check the receive buffer on the Oki. I usually set it to the highest (88k or 128k). You might also check the print head gap if you are printing multi part invoices. If the print head is too close it may overheat and stop printing. If you have a different printer, swap it out and see if it prints correctly. It may be a problem with the JetDirect 170x, not the printer.
Nov 08, 2007 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
265 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
