Sent job immediately places printer in pause mode
  • 4,323 Answers
Hi
Try and turn off the printer and unplug it for 10-12 minutes. Restart and check if it is still behaving the same way. If the printer is on a network then try and reinsert the cable and check. If this doesn't resolves the issue then restart the printer spooler. To restart the print spooler, go to Start menu-> run-> type services.msc ->select print spooler from the list -> right click on it and select restart. Now the issue would be resolved. Hope this helps... If it does please do not forget to accept the solution. Or else post back for assistance with the model number of the printer & error/s if any.
Daniel
Posted on Aug 28, 2010
How do I take Canon imageCLASS D320 All-In-One Laser Printer off from "paused" status?
On the printer properties on the computer there will be a paused option (Normally marked as "Pause Printing") in the printer drop down menu on the Printer Queue screen. Click this to remove the tick next to it and it should start printing again.
Feb 20, 2015 | Canon imageCLASS D320 All-In-One Laser...
What does it mean that printer is on "pause"
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer
1.) Left click Start in the bottom left hand corner of the screen
2.) Left click Control Panel
3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
4.) In the Window you will see your printer, double-click your printer
5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Hope this helps :)
May 15, 2011 | Epson Stylus C66 Inkjet Printer
It keeps saying memory low, what should i do
If you already sent a job to print, wait until is finished. These printers have internal memory, like the pc RAM, and if is not big enough you get this message. You can upgrade this memory to a higher capacity. If you haven't sent anything to print, check the printing queue, sometimes it has paused/stopped printing jobs that use up the internal memory.
Feb 09, 2011 | HP LaserJet CP1515n Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Printer is printing foreign looking characters all on its own. No print jobs are being sent to the printer. Printer is set to DEC mode and the macro has been reloaded several times. As soon as you put the...
It sounds like data is being received by the printer from an outside source.
Try disconnecting the printer from the computer system so it is a free standing printer. Power the printer ON and put in ONLINE if you do not get strange characters printing the print job is definitely from the computer system some place.
If you do not get the print jobs printing when the printer is disconnected from the computer system, it could be that the print jobs are being sent from the wrong driver or print queue on the system, you may need to try to identify who is sending the rogue print jobs.
Feb 10, 2010 | TallyGenicom LA800+ Matrix Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Oki Microline 420 Network Card
As the alarm is on and steady then you most probably knocked the change lever into a position where it detects no paper loaded. The easiest way to check is to load your paper and move the change lever until the error lamp goes out!
Sep 08, 2017 | OKI MicroLine 420 Matrix Printer
Cancel already sent job
turn off the printer, and disconnect from computer..turn it back on, and clear all jobs from front panel controls
Mar 20, 2008 | Brother HL-2040 Laser Printer
Not printing print jobs
pause all the other jobs and print only the one you need. if the memo is with in the print job go back to your software that you use to create it and select to print just the page number you need.
Dec 04, 2007 | HP Photosmart C4180 All-In-One InkJet...
Pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Jun 18, 2007 | Epson LQ-570e Matrix Printer
Computers & Internet Logo
David Payne
David Payne
