Question about Sony PlayStation Portable White Console
When i turn it on it always turns off - Sony PlayStation Portable White Console
    Novelist:
  • 142 Answers
This issue can be caused by many possibilitys. The 3 most common malfunctions are bad battery, blown fuse, or damaged LCD screen. If the battery shows that it's holding a charge then that is most likely not the issue. If the LCD screen comes on for a second and flashes white that indicates that is an issue with the LCD screen. If not than your issue is most likely due to a blown fuse.
There are some great video tutorials located on Youtude describing how to fix these issues
I hope the info listed above has helped in some way.
If possible please rate this solution.
Posted on Aug 28, 2010
How to turn on and off data on the alcatel pixi unite a466bg?
Settings - Aircraft Mode
Data is normally always on by default. The only way to turn it off is as above, which also turns off you phone signal as well. Turns your phone into a paperweight.
Jan 09, 2017 | Alcatel Cell Phones
02 Buick LeSabre Ltd. Rear flashers work (blinking rapidly), front bulbs stay on, inside indicators also flash rapidly. Replaced control module under the dash. Did not help. What else could it be?
Hi there., when flashers/indicators work rapidly on the dashboard you should check whether it is the same on the actual bulds. Fadt flashing is usually a sign of a bulb failure somewhere. If everything is functioning ok externally I would consult a competent technician for a diagnosis.
Jun 08, 2015 | 2002 Buick LeSabre
What is the probable cause of the fan turning itself on?
To diagnose i would check if the fan "always" turns on in the start of microwaving a meal? and or if it gets hot and then "always" turns off at a certain time?
if it always turns on and then turns off at a time such as 30 seconds, probably getting hot and over heating - replace fan motor
if it turns on for the first meal but then is off or on intermittenly probably a switch or wiring is loose.
Jul 03, 2014 | Electrolux Microwave Ovens
Motor on but jets only work sometimes
need more information about what kind of control you are using to turn the tub on/off.
does it turn off when you can get it turned on?
Rod
US Parts Center
888-521-6183
May 06, 2013 | Kohler Home
My samsung champ always appear connected to pc! and it always apear to be charging even if unplugged?what should i do?
My samsung champ always appear connected to pc! and it always apear to be charging even if unplugged?what should i do? thnx...
Mar 14, 2011 | Samsung Cell Phones
The print always prints one page when I turn it on
You have to go into the menu and turn off the Start Up Page and/or the Configuration page.
Feb 02, 2010 | Xerox Phaser 6200N Laser Printer
When turning on the burner, the gas does not always flow
There is usually a switch under the knob thaat controls the electrical sparker. OFTEN these get messed up when the area around the knob is cleaned and water gets behind the knob.
Dec 05, 2009 | GE Cooktops
Car always turns over but does not always start with first turn of the key but then always starts with second turn of the key?
Try changing the fuel filter.
When you turn the key it activate the fuel pump. Gas is then pump to the engine to start.
If you see no improvement then try some thing to clean the gas tank. ( gum out)
Mar 10, 2009 | 2001 Pontiac Grand Am SE
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Sony PlayStation Portable  White Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
