Question about LG Refrigerators
WHY DOES THE FREEZER DOOR OPEN WHEN THE FRIDGE DOOR CLOSES
  • LG Master
  • 43,501 Answers
It opens because of the excess air pressure inside when the door closes... the door should hold tighter then that but if it is sealed very well the air acnnot escape fast enough and causes the pressure increase that blows the other door open...
heatman101
Posted on Aug 28, 2010
We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Dec 30, 2016 | Refrigerators
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
Freezer door pops open
when you close the fridge door you create pressure in the fridge and the freezer door may pop open, close it more softly. or there may be stuff pushing against the inside of the freezer door
Mar 05, 2012 | Maytag Refrigerators
The freezer door pops open when the refrigerator door is closed. A service man already looked at it and leveled it, but it still is a problem. The freezer door has a tight seal when used on its own.
It does this because as you close the door, the air pressure goes to the freezer somehow, maybe through a venting that vents cold air from the freezer to the fridge. The resulting pressure in the fridge, goes to the freezer, and opens the door.
Nov 27, 2009 | GE GTL22JBPBS Stainless Steel Top Freezer...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Fridg not cold
your story is very odd but likely nobody is messing with the door switch hwen you moved , or the wires could have shorted out. normally, the door switch, when you open a door would switch on a cabinet light and turn off the blower. in your case, its the reverse, as you open a door, the blower runs and if you close the door, the blower stops. im not sure if you can figure out which pair is the normally close and which one is the normally open on the door switch in order to swap them or you may rplace the door switch.
Feb 05, 2008 | Refrigerators
Doors not sucking closed
This is not a fault but it is a design problem that cannot be resolved, the problem occurs because between the fridge and the freezer there is an air duct to allow the freezer air to be blown into the fridge however when you close the fridge door this forces the air back into the fridge, the result is that it is forced into the air duct and pressurises the freezer or visa versa and pops the door open to allow the compressed air to escape. soory no cure to this one. Regards Advisor
Sep 01, 2007 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
57 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
