Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an rca 52 inch lcd tv . when i turn it on the green light on the front comes on then goes off three times. i had to repeat this 3 to 4 times to get it to come on, but now it quit coming on altogether. please help.
  • 1694 Answers
SOURCE: 52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Posted on Apr 15, 2008
  • 1030 Answers
SOURCE: RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Posted on May 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Posted on Jun 29, 2008
ladywinn
  • 5138 Answers
SOURCE: 52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Posted on Dec 09, 2008
the circuit board behind the power on and off button needs to be replaced very easy fix.. good luck everyone
Posted on Jan 09, 2009
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
My 52 inch RCA HD/TV Does not turn on
Replace CP150 on the deflection board and that should take care of the problem since it starts once in a wnile if it didnt start ever then you would need the 259296 flyback and the CP150 Capacitor.
May 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
http://servicemanuals.vstore.ca/
Feb 07, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a 52" GE-HDTV/Monitor. After the unit is turned off, it will not come back on-at all now. When I try to turn it on, the green light on the front of the TV comes on briefly, then goes off. I can...
replace CP150 CP114 and CP120 all three capacitors are available at the following link with free instructions they are listed under the RCA parts category which are the same ones for your GE TV.
Jan 17, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Tv does not come on
IT SOUNDS LIKE A FLYBACK NEEDS REPLACED (PART COST AROUND $70.00
Dec 06, 2008 | RCA P52960 52" Rear Projection Television
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA will not turn on
I had this problem on My RCA tv, what I found was a couple of bad green capacitors in power suply there are around three of them I just replaced 2 of them if I am not mistaken one of them is C120 but if not change all three this are the value of the ones I replaced 2200uf 16v and 220uf 35v, if you see on top of the green capacitors you will notice they are bad.
My tv is working for more than a months and I had the same problem as you are having.
Oct 21, 2007 | RCA HD52W58 52" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
484 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
