Question about Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator
Freezer keeps overfrosting - Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
What numbers on a dial mean the coldest my freezer keeps icing up what number should I have the dial on
Not sure what you mean with icing up, but in every freezer, vapour will freeze to the side.
If you want to go for sure, just buy a little thermometer for the freezer (must be going at least to - 30 Celsius) and hang it in the freezer. 3 or 4 star freezers should be at -18 Celsius.
Lower does not add anything to the quality of the food, or can extend the time you can preserve it in the freezer, but will cost more energy to keep it that cold. Lower than - 18 will shorten the time you can keep food in the freezer. -18 C is about -0,4 F.
so 0 or above is bad. -0,4 or below is good.
Sep 22, 2014 | Refrigerators
There is frost buildup on the backside of my freezer, could this be the problem behind the freezer and refrigerator not cooling
Yes it absolutly the reason the refrig. section is not cooling,when it overfrost such as your experiencing,the freezer coil is one huge block of frost and no air can be passed through it into the refrigerator to cool it.
I have written this tip of what to check when it doesn't defrost automatically as its supposed too,
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 10, 2011 | Refrigerators
Freezer overfrosting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | Microwave Ovens
My sub zero is about 12 years old. at what number should I keep the refrigerator and the freezer?
please FORGET the numbers,they are just GUIDES get a thermometer and keep the fridge at+5C and the freezer at -18C.(keep it inside the freezer)
Nov 04, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer side builds up ice on back wall ,then both sides stop air flow
Hmm excessive moisture entering the unit - this can happen with excessive door openings or bad seal gaskets - make sure the seal is tight and not worn out. You are talking about frosting on the freezer outer wall right not behind the back panel ?
Try removing the back panel and look for icing/overfrost on the evap coils too - that could signal a defrost problem inw hich case you would need to inspect and change the control board or defrost timer components.
Sep 26, 2009 | Kenmore 53642 / 53644 Side by Side...
No cold air blowing into the refrigerator - temp too low
You have your own answer there - You have overfrosting and icing up behind the freezer, this will affect proper cooling - also if you have seperate freezer and refrigerator controls, it's possible the damper is not opening properly to let the cool air in. But in your case it sounds like a defrost problem. You will need to have a service person inspect your control board and defrost timer components - sometimes it's as simple as a board replacement due to a burnt resistor these things are the most common causes.
Good luck
Sep 25, 2009 | Kenmore Refrigerators
The refrigerator not as cold as before
Things to check - door gasket seals for leaks, dirty condensers that need to be cleaned and dust removed, proper clearance to the back and sides of your unit.
Is your evaporator fan in the freezer functioning normally ? is your freezer cooling normally ? You might want to check at the back of your freezer panel for overfrost on the evaporator that will impact cooling performance. You can shut down your unit and try manually defrosting and melting the ice and then run your unit for a couple of hours to see if cooling is back to normal........ if it is, then your defrost system is malfunctioning and you will need to have the control board and/or defrost system components checked.
Otherwise, if overfrost and door seals and dirty condensers are not an issue and you have also tried raising the cooling dial up and compressor run-time is excessive then you may have a sealed system issue but rare and not the common causes. Most common causes are overfrost on the evap / defrost timer problems and damper (flaps that do not open properly).
you will need to have those checked if all else fails.
Sep 23, 2009 | Imperial Refrigerators
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Freezer all of a sudden started major frost build up owned for approx 6 months mostly on left side seals all look tight french door style
I was going to suggest you have a leak - outside warm air / moisture coming in your freezer but you mentioned the seals are tight.
The next most common problem is your defrost system - refrigerators use 2 methods to control forst - timer defrost or adaptive - adaptive is used on newer ones and will defrost as needed - the timer version is based on your compressor run time - about every 6 to 12 hours or more or as needed, your compressor motor will turn off and you should see what looks like a red/orange heating element through the vents in your freezer and hot air coming out - on some freezers it is hidden and you won't see it, but you will notice hot air - you will hear sizzling sounds, and water dripping - that is your defrost kicking in - there should NOT be frost build up at all iny our freezer - if it is the case, then your defrost timer is faulty or the control board needs to be changed, all this is at the back of your freezer panel, you have the board, heating elements, defrost timer and limiter - all these components need to be checked when you have your unit serviced. Overfrost of the evap will cause your refrigerator and freezer not to cool properly as well.
Sep 01, 2009 | Samsung Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GX5FHTXT Bottom Freezer French Door Refrigerator Logo
99 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
