Question about Mitsubishi WS-55819 55" Rear Projection Television
After the set is on for awhile, the picture screen bows really bad and makes you unable to see it. It is a WS-55819 manufactured in November 2001
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If picture gets 3d etc, it is convergence problem.
See attached typical photos.
The model indicated uses two of the STK-392-570 chips for this and total parts cost will be under 25 dollars to fix set.
I also have start to finish, step by step instructions for this repair in this model.
If the information or the photos told you something you did not know rate this solution as very helpful as I do this here for free.
No two sets with convergence problem will look exactly the same but you will know if you have the same trouble.
Posted on Aug 28, 2010
  • 1 more comment
  • frizbeedude Nov 01, 2010
    Good afternoon. I have the same tv (WS-55819) with the same issue. Can you email me the instructions (frizbeedude@comcast.net)? Thank you in advance.
  • haas747 Dec 01, 2010
    I am having this problem how do i fix it
  • stellanabors Dec 09, 2010
    This was very very helpful Sir.
    Thank you
    Star
Ws-55819 has code 22. It will power off within seconds.
Error code 22 on this model is most freguently a problem with convergence. Error code 21 is usualy the DM module.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Convergece problem - Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself
Apr 23, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Picture is bowed and colors are not aligned
This called Projection TV convergence. Take a look on this site for a tip on Projection TV convergence.
Apr 19, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS 55859 Green light flashing
HELLO. WELL SOUND'S LIKE YOU A PROBLEM.!! THAT COULD BE A FEW DIFFRENT THING'S.!!! FIRST THING YOU WANT TO DO IS UNPLUG THE SET..!!! THEN TAKEOFF THE BACK.!!! AND LOOK FOR FUSE'S ON THE BOARD. TO SEE IF YOU HAVE A BLOWN FUSE.!!! GET BACK TO ME AND LET ME KNOW .? OK ASAP. "GOOD LUCK"
Jun 15, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi TV Picture Bowing
You will find a very good guide here and here to fix your TV.
This might not be a DIY if you do not feel comfortable. The repair shops charge about $350.00 to $400.00 for this type of repair.
Apr 19, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Bowing at bottom
convergence ic bad, should also replace bad caps in DM
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
· http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Problem with 480i
 This problem has been around for awhile.
 The 2HDW PCB needs to be replaced. Part number 935C966001. It sits on the signal board underneath a metal shield.
 Not a bad repair and remember to unplug the set if you are going to do it yourself.
 Respond to this post if you have any questions and I will reply.
Oct 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Convergence - bow problem
If you know how to solder on a solid state pruinted circuit board, try to first resolder the convergence IC's. There are two of them, they are black and stand up on a metal heat sink. The IC's will start with stk and have some numbers following that. Sometimes you can get away with resoldering BUT most of the time they have to be replaced. Consult a trained service person if you dont have any TV repair experience as thei like I said is a solisd state set and trhere are really no user replaceable parts inside of them.
Sep 30, 2006 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
375 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
