Question about Texas Instruments TI-30XA Calculator
How to find the mean on the calculator - Texas Instruments TI-30XA Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press SHIFT x^2 to use the mean function.
Refer to the "One-Variable Statistics" section in the manual (page 9).
Posted on Aug 30, 2010
HOW DO I CALCULATE THE MEAN IN GRADE 11?
a how to video on how to calculate the mean.
Sep 23, 2014 | Miscellaneous
What does the mr mean on a calculator
What make and model calculator? On most calculators with such a button, it means "memory recall." Press the button to recall the contents of the memory.
Apr 17, 2014 | Office Equipment & Supplies
Find mean ti30xa
Clear the statistics registers with 2nd [CSR]. Add the data points with Sigma+. Errors can be corrected with 2nd [Sigma-]. Calculate the mean with 2nd [xbar].
See the example on page 11 of this guidebook.
Feb 24, 2013 | Texas Instruments TI-30XA Calculator
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
I have 50 data points for which i need to find standard deviation on a classpad 330 , is there any quicker way to calculate than minusing the mean from every data point?
Here is one technique I used on the TI84Plus.
Create two lists list1(50) and list2(50) of equal dimension (same length)
You will have to find how to do it on ClassPad.
Fill list2 with zeros
Fill list1 with your data.
Sort the list in ascending order (if it is not sorted)
Do standard deviation calculation on list1 (or calculate the average)
The mean of the data is in a special variable (xbar)
From the command line using the list syntax calculate abs(list1-xbar) and store results in list2, overwiting the zeros.
Perform standard deviation on the new list2. You will get the mean deviation from the mean in the variable xbar.
A simple request from you. Can you please not use MINUS as a verb? By doing so you are propagating incorrect usage. There is a short and correct way to express the operation: to add.
May 05, 2012 | Casio ClassPad 300 Calculator
How to calculate mean using sentry ca656 calculator
press shift and cal in stat mode then presss value and them m+ then value the m+ them press x-m buttom its mean......
Feb 07, 2012 | Sentry CA656 Calculator
Turn off deg
If you mean "BEG" then press g [END] (the blue "g" key followed by the "8" key) to switch to the end payment mode.
If you do mean "deg" but on a different calculator, then please reply to this post and specify the calculator.
Oct 25, 2011 | HP 12C Platinum Basic Calculator
I want to calculate mean value and standard deveation of empty crates 50numbers
Full instructions are in the "Statistical Calculation" section beginning on page E-44 of the manual. If you need a manual, you may download a copy here.
In short, you go into the STAT mode, bring up the STAT Editor screen, enter the 50 data points, then calculate the mean and standard deviation.
Oct 13, 2011 | Casio FX-115ES Scientific Calculator
SHARP EL-531W HOW DO YOU CALCULATE MEAN,STANDARD DEVATION FREQUENCY OF 95,80,80,75,75,50
for the mean, just add them together and divide answer by the amount of figures you put in. as for the others, i'm not sure a standard scientific calculator will do that
Jun 11, 2009 | Sharp EL-531VB Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-30XA Calculator Logo
87 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
