Question about EnGenius EOC2610 80211g Outdoor High Power 600mW Client BridgeAccess Point with Signal Strength L (EOC2610)
I am trying to setup my set up a Access Point at my house with the following product. a EnGenius EOC 2611P. when i set security on the device it is not sending an ip address to the computer. is there a simple configuration manual out there Thanks for your help.....
  • 481 Answers
Assigning an IP address to a computer is a function of DHCP. Either the access point's DHCP server much be enabled, or a DHCP server somewhere on the network to which the AP provides a path must be enabled. There should be only one DHCP server per LAN.
For example, if you have a home router handing out DHCP addresses to computers in your home, and you wire this AP to your router to wirelessly serve an additional computer or computers in a remote location, then its DHCP server should be off, because DHCP service will be performed by your home router to both local and remote computers.
However, if you connect this AP directly to your network interface and serve ONLY computers in a remote location, then its DHCP server should be on, so that it will provide DHCP addresses to the remote computers (because your network interface in general won't, unless it is also a router itself, in which case see the previous paragraph).
Posted on Nov 01, 2010
EOC 2611P. I follwed the instruction to configure the antenna and when it come tthe time when i typed 192.168.1.1, i don't get the log in box for the antenna. I've been trying many time and i am jammed...
In order to log into this device, you must first configure the TCP/IP settings of your PC/Notebook.
1. In the control panel, double click Network Connections and then double click on the connection
of your Network Interface Card (NIC).
2. Select Internet Protocol (TCP/IP) and then click on the Properties button. This will allow you to
3. Select Use the following IP Address radio button and then enter the IP address and subnet mask.
Ensure that the IP address and subnet mask are on the same subnet as the device.
For Example:
PC IP address: 192.168.1.10
PC subnet mask: 255.255.255.0
4. Click on the OK button to close this window, and once again to close LAN properties window.
Login username and password are both admin for this device
All info on this device can be found here http://www.engeniustech.com/resources/EOC2611P%20User%20Manual%20v1.0.pdf
Mar 12, 2011 | EnGenius EOC2611P 80211bg Wireless Access...
Trying to connect Blackberry to EnGenius EOC Access Point - BB keeps saying it fails to get an IP address from the AP - how do I fix?
It sounds like your AP is not set up to be a DHCP server. If you want to use devices with your AP that expect to receive addresses over DHCP, then you either have to enable the DHCP server on your AP, or enable one somewhere else on your network to which your AP provides access.
Aug 06, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
WDS Setup
In a WDS network, all the access points need to be in WDS mode, and one of them needs to be wired directly to a routed internet connection.
Here is a very good detailed tutorial on how WDS works and how to configure and troubleshoot your own WDS network:
How To: Setting up WDS Bridging / Repeating
Jun 03, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
How to extend lan with engenius
This is a lengthy topic. Full instructions answering exactly this question can be found here:
EnGenius 2610 / 1650 bridge router configuration
Jan 22, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius EOC2610 80211g Outdoor High Power 600mW Client BridgeAccess Point with Signal Strength L (EOC2610) Logo
418 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
