Question about HP Business Inkjet 3000 Printer
Message saying reinstall Cyan Printhead. We have tried 2 brand new Cyan printheads. Still getting message. It wont let us do anything until we clear this message. Any Suggestions?
  • rerab Jan 14, 2009
    I have the same problem except it is with the yellow cartridge. Replaced both yellow cartridge and print head. Whats next?
    Genius:
  • 3,587 Answers
You may wish to clean the nozzles, and do a clean and calibrate
Posted on May 07, 2008
Business inkjet 2230 shows need to replace cyan printhead, have done so twice and message keeps reappearing?
Hi
From the cartridge costs it looks as if the cartridges incorporate the printhead. If this is the case - are you using HP cartridges or compatibles. Sometimes compatibles don't work when the printhead s the problem.
If you are using HP cartridges then make sure the contacts on the cartridge, and on the printer are clean. Apart from these comments I'm afraid I'm also stumped.
Good luck.
Aug 27, 2014 | HP Business Inkjet 2230 Printer
HP5500 UV...after paper jam I have a replace lt cyan printhead message and recover black printhead.
The Lt Cyan printhead may have been damaged by the paper jam.
I recommend removing all the printheads and power cycling the machine (turn off then back on) Install the printheads and check that each one says OK. Replace any that show recover or bad. (HP will replace free if it is under warranty - return it to the store you purchased it from)
Nov 15, 2011 | HP DesignJet 5500PS InkJet Printer
Hp Business Inkjet 2800 printer prompted me to change the cyan printhead. I changed the cyan printhead and it is not detecting the new printhead. A printer repairman came to inspect the printer and...
Hi
Did you check the connections in the carriage if there is little amount of ink on the contacts? if not then clean it well with a dump cloth and try to re-install the old printhead it will sure accept it. If not then the other way is to change system date of the printer first and then try again.
DO RATE MY SOLUTION
Jun 30, 2011 | HP Business InkJet 2800 Printer
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
Asking to replace new printheads
is it laser or inkjet, and cartridges are original ones or compatible ones, some printers will not accept comptible cartridges.
May 03, 2010 | HP Business InkJet 2800 Printer
My HP Officejet Pro L7780 All-In-One InkJet Printer was jammed with paper. I believe I got it all out and now the display reads" Printhead problem- the following printhead has a problem: magenta/cyan...
There are two possibilities here Joanne, first, it could be a false error message or else second, the Cyan/Magenta print head has gone bad.Try the following:
1. Take the Cyan/Magenta printhead out. Remember, the printhead...not the cartridges.
Clean the copper contacts with a Q Tip, moistened with plain water. Wait till it dries, put the printhead back in.
2. If this does not resolve the issue, unplug the power cord from the back and press and hold the power cord for 30 sec. This will drain all the static charges. Plug it back after a couple of minutes and see if the error message re appears.
Jul 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printing with my second hand hp officejet d145
You can clean it with maybe a little alcohol then go thru the motions of cleaning from the printer controls
Feb 26, 2009 | HP OfficeJet D145xi All-In-One InkJet...
Bad cyan printhead
try to clean with tissue will mostly solve if does not solvethen go for replacement.rate this as fixya to encourage us to solve more and more problems like yours.good luck.
Jun 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Open Questions:
HP Business Inkjet 3000 Printer Logo
428 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
