Question about Hampton Bay 44 In. Bistro, Copper Kitchen Fan
I have a 3 wire replacement light switch but the one in the fan only has 2 wires. Can I use the 3 wire switch? If so how does it wire up?
  • 377 Answers
Kind of hard to be 100% sure without seeing the switch, but seems like the old switch was a simple single pole on/off switch while the new one is a multiple pole switch. The old switch had two positions, off and on. The new one most likely is off/on/on, perhaps used to turn on two banks of lights similar to a 3 way switch on a floor lamp; off/dim/bright. Sounds like it could be used provided it fits physically. Wiring would be power in to one wire and switched to one of the output wires. The third wire should be covered properly with a wire nut and tape to keep it from shorting out. However, there will be a position on the switch which will do nothing at all. After having said all this, I would suggest you purchase the correct switch as the replacement.
Posted on Aug 29, 2010
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
  • 37 Answers
SOURCE: Replace exhaust fan with fan & light?
Let's say you originally only had one switch (to operate the fan). And at the fan you have only one black, one white, and one ground (bare or green). You can still put in a fan/light combo. but both the light and the fan will always come on together when you flip the switch. To do this you'd connect the black from the switch to the black AND the blue on the fan and connect the white from the switch to both whites on the fan and connect the ground from the switch to either a green or bare wire on the fan or to a green screw on the fan housing somewhere (whatever is available).
Posted on Jan 29, 2009
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Fan speed control on 2 way circuit
1) Guessing you have 3-way switch where 2 different switches control same Load (light, fan, motor). Unknown wiring, and unknown if fan and light are wired separately.
2) Google search for 3-way fan switch shows Leviton IPF05 with simple straight-forward wiring. Link below has instruction manual, and Live chat button located to right of LEVITON
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=IPF05-1LX&section=47082&minisite=10251
3) It appears that the Leviton device must replace Line side switch.
http://waterheatertimer.org/images/GE-15312-3-way-circuit-600.jpg
4) Uncertain if this device also controls fan since the wiring is so simple.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 22, 2013 | AMS Lutron SFSQ-F-HO Skylark Single-Pole...
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
Replaced a light switch for a ceiling fan. Switch
On the switch ... one wire goes to thefan or the light and the other wire goes to the power.
All white wires normally go together.
Jun 05, 2010 | Hampton Bay 52 In.Carriage House II in...
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Jan 21, 2009 | Solar 2-wire Pull Chain Light Switch For...
Wiring p fan speed cotrol switch
most common fanlight control is 2 dimmer switches in parallel to control fan spped and light, direction is still usually controlled on the fan body
requires 3 wire in the light box, and a compund dimmer, this one has left and right and fits a single switch box
where a fanlight is used to replace a regular household fitting there is often only 2 wire in the switch box, either a sparky can fishtape an extra cable along the lamp cable, or replace the wire,
the 3 wires from the fanlight are light fan and neutral
some new retrofit fanlights have remote controls to negate rewiring
Apr 26, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Hampton Bay 44 In. Bistro, Copper Kitchen Fan Logo
97 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
