Question about MSI P965 Platinum Motherboard
I got the msi p965 platinum board today secondhand i installed it and double checked all connections. i installed my 9500 gt gfx card and pluged everything in and swithed on there is powere permanently but nothing comes on the screen at all.. i have 2x 2g DDR2 800 ram a 2.8Ghz processor a 160G WD IDE HDD 9500gt gfx card even tho the card is second hand it was from a friend and i saw it fully opperational yesterday.. pleage help
  • 29 Answers
Boot into your bios when you are first turning on the computer(Press Del while the Press DEL to enter SETUP message displays on screen after powering on the computer.) and look and see if you have "only use on-board graphics" set. Sometimes you have to click the arrow and choose"use graphics card" instead of the system only using your on-board graphics.
Posted on Jul 02, 2017
shugster
  • 93 Answers
SOURCE: display driver
can you send me the make and model of the lap top please ?
Posted on Nov 14, 2007
  • 176 Answers
SOURCE: MS 6712 motherboard
check the cables, and if all connection pins are on the drives or on the motherboard. Not all the needed communication routs between the drives and the motherboard are working....
U can also try another IDE slot (if more than 1)
If all checks ok, try a BIOS reset... (but most probably is just the cables ...)
Posted on Jan 20, 2008
jose_v17
  • 229 Answers
SOURCE: Computer will not turn on
The only way you can see if it the motherboard or the card is to try them in different machines I.Eputting the card in a buddys pc and try another AGP card on your board. I am glad that we were able to figure out the problem
Posted on Mar 25, 2009
dave836
  • 12 Answers
SOURCE: MSI P6N Platinum not booting up
Have you plugged in the additional power supply connectors to this board at JPW1 (under the heatpipes towards the rear connector panel)? If not then you need an 8 pin 12V power supply from your PSU to this connector (This is what powers your CPU). If you don't have an 8 pin connector, you can get away with a standard 4 pin. It will only fit in one way, so you'll know.
It may sound like a daft solution, but you'd be amazed how many people forget to plug this connector in on this and similar boards.
Posted on Oct 06, 2009
  • 22 Answers
SOURCE: "Memory Turbo Card must be installed with either DDR2 or DDR3"!
It is not DDR2 or DDR3, it is new memory technology developed by Intel which is a flash memory module which reduces the time it takes for a computer to power up, access programs, and write data to the hard drive.
Posted on May 03, 2010
Ddr2 533 cl4
The drivers can be found at MSIs website. Click on Download tab, then Driver and it will list all the SATA, realtek drivers available once you chose your OS.
You'd have to go to the following URL:
http://www.msi.com/product/mb/P965-Platinum.html#/?div=Driver&os=Win7 64
Nov 04, 2013 | MSI P965 Platinum (7238010) Motherboard
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
I have an OEM PC with mainboard MSI p965 Neo Today it is not working (no startup screen, no ugly beep messages etc).. I have only a blank screen..
First of all test the power source on its own. Good? Take out the board of the case and keep on it just the video card and try to boot into the BIOS. No good? Try to boot using another video card, then another memory sticks and finally another processor. If none of them had an effect then the motherboard is dead, replace it.
Jul 25, 2010 | MSI P965 Neo-F Motherboard
Where does the cable go to on main board from MSI Geforce 9500 GT it's to wires but a 3 prong plug. Is it for the fan?
yes is for the fan you can cut the connector if the pins aren't allready next to each other. yel or red is allways + in a pc
Dec 13, 2009 | MSI GeForce 9500 GT,, PCI Express Video...
Oct 06, 2009 | MSI P6N SLI PLATINUM Motherboard
Network Connections are Gone!
I would check in device manager (control panel) and see if the network card is listed. It probably has a yellow exclamation point next to it.
If there is an exclamation point there, then right click the card and click uninstall.
Next, using your wifi to access the internet, download the latest network card driver from the PC vendor website / Motherboard vendor site / discrete network card site.
Install the network card driver and you should be back in business.
Jul 08, 2009 | Computers & Internet
SATA configuration for MSI P965 Neo --- JMicron hell!
Once you have loaded your main board drivers,configuration should be pretty much automatic.Personnally,I have my dvd drive on the standard IDE ribbon cable header,and 2 SATA HDD.One on each SATA header.After loading The mainboard Drivers,Windows did the rest.I haven't found any need to mess around with any BIOS settings at all.
I currently am using a Biostar P4M900 board,but I have dealt with MSI before,and they are pretty much the same deal.
Feb 07, 2008 | MSI P965 Neo-F Motherboard
DRIVER DOWNLOADS
If this Mb is a P965 Platinum than this is where you need to go:
http://www.msicomputer.com/product/p_spec.asp?model=P965_Platinum&class=mb You get a chance to see the Mb too. Does this look like yours?
If you think it is a M2NPV-VM Socket AM2 than go to:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Fill in the search window on the right side. Select, Motherboard
Than pick SocketAM2/AM2+
Than pick M2NPV-VM The driver page will load.
Dec 19, 2007 | MSI P965 Platinum Motherboard
MSI P965 Platinum Motherboard Logo
83 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
