Mixers
Problem for Mixers
Generic problem for all Mixers
Kitchen aid mixer
By peggle on May 07, 2008
I have a profession 575 watt kitchenaid mixer that is not working properly. It is leaking from the beater shaft and the beater is not rotating as the mixer turns. I think something inside is stripped. Is this fixable?
Best Solution
posted on May 09, 2008
Helpful)
defrankond
Rank: Wiz
Rating: 82%, 41 votes
the unit sounds like the drive unit is stripped. if the planitary unit is spinning that gear is ok but the one below that is stripped. which is the one that spins the beater. Usually the professional lines are covered under a 2 year warranty. where as the others are a 1 year. I would contact kitchenaid first and see if your product is covered for replacement. they are really good about replacing faulty units. if not the unit can be repaired. It is a simple process and you can buy the parts off kitchenaid. usually the parts come with instructions as to how to replace them but if not repost to me and ill get you the directions on how to replace it.
Was this helpful?
Yes
No
Popular Solutions for Mixers
Questions and Unsolved Problems for Mixers
Answer
where can I buy the Kenwood Stand Mixer In Canada BC
Answer
Which Kitchenaid Mixer is the best 325 watts or 450 watts?
Answer
we cant get the mixing paddle off seems to be locked in
Answer
my mixer runs great except it doesn't seem to get quite as fast as it used to.... almost like 'top... (More)
Answer
kenwood chef stopped working power to switch but no further
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mixers:
Top Mixer Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Mixer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
