Question about Maytag Neptune MAH5500B Front Load Washer
Average cost of replacing bearings on maytag neptune front load washer.
  • 16 Answers
SOURCE: my maytag front loader will not drain water oe comes on the control panel
Hi, Take the outlet pipe,usually goes into a stand pipe, lay it down into a bowl and the water should empty, lift it up when the bowl is full, and if necessary repeat. If it does not empty, there could be a blockage in the pump, or the filter. Tom.
Posted on Mar 15, 2007
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
  • 50 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
Check for obstruction in pump located at back of machine. Remove back panel and pump will be located on left hand side.
Posted on Feb 23, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
  • 530 Answers
SOURCE: I need to replace the molding door boot seal on my
you need to first unplug the unit. next you need to remove 4 screws that hold the dispenser lid on. next open the door remove 4 screws. remove the door and the out side panel. next located to the top left and right you will see a bracket with a 5/16 bolt remove them and take the bracket off. next lift the lid. you will have access to the door seal. you will see a spring at the top that is the band that holds the seal to the tub. the front of the seal just peels off. when putting the band and spring back on may be a little tricky. get one side up to the top gett a piece of duct tape and secure it. so that you can properly get the rest of the band on without fighting with it. get some vise grips and pull the spring over and attach to the part that is tapped. let me know if this helps or if you need more instructions.
Posted on Jun 21, 2009
I have a maytag neptune front load washer. When spinning it makes a loud noise. Could it be a bearing, what would be the price to fix it, and how hard is it to fix?
would most likely be rear bearing have to replace spindal with it/parts are costly and that is one of the tougher ones to do ..check you warrity may still have some on outer tub and inner basket...good luck
Feb 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer is extremely loud during the spin cycle and the detergent dispensing door is broke, How much would I be looking at out of pocket to get it fix or would it be cheaper to replace it...
The loud noise during the spin cycle is probally due to a bearing failure. Not sure how much it would cost to fix, but Maytag does not sell you the bearings but would sell you a new wash tub with the bearings installed for over $600! Add the labor costs which would be a lot since the machine needs to be taken apart to install a new tub, and you would be ahead of the game getting a new washer.
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
DRUM BEARINGS ARE BAD. WHAT I NEED IS STEP BY STEP INSTRUCTION ON HOW TO REPLACE BEARINGS. NEPTUNE WASHER, MODEL MAH5500BWW
The wholesale cost of the part is about $400+shipping. You'd pay more...
I'm in the business and mine did the same thing. When we couldn't turn the TV up loud enough anymore, I pitched it and bought a Duet!
Sep 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
When the washer is in spin cycle it makes screehing noise!
You peobably need bearings... See www.neptunebearing.com for replacement bearings and they also rent a special tool designed for the Neptune bearings and it includes use of a DVD that shows you how to disassemble Neptune, replace bearings and install the seal kit.
Apr 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
239 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
