My printer works but 24hours or so late.Is there a time delay switch that I have used by mistake.
    Genius:
  • 3,587 Answers
Hhh?????uhhh???...now that's really unusual, is it not? Are you suggesting that a print job runs 24 hours after sending it to the printer?
I'd suspect the date settings are off by a full day on the printer setup.
Posted on May 07, 2008
Why are our statements late every month but the bill must be paid
That's the question of the month. They can send when they want and can also tell you it's due on receipt. So, the only option you have is that the postage / email date is later than the due date - then you can prove they didn't send on time
Sep 07, 2017 | The Computers & Internet
Watch taking 14 hours to charg
I made the mistake of purchasing a Citizen automatic rechargeable watch that is supposed to recharge with any light source. Not true.
It must be in daylight or else it will stop working.
It was left on the window sill for 24hours before any signs of life!
Mar 09, 2017 | Watches
Flights arrival times Emirates Flight EK25 is due in Glasgow at 7.55 p.m. today. The Web site reckons it is on time. I checked first with the Dubai Airport web site who reckon it is delayed (by some
The departing airport will not usually have the destination arrival time of a flight. It's possible the time you saw was a delay in departure time, however favorable weather and a strong tailwind can help a flight make up lost time.
Looks like it the flight departed 20 minutes late and landed 12 minutes late. 11:10 11:30 18:55 Landed 19:07
Aug 24, 2014 | Cell Phones
My Brother printer will not find an IP on the router. I've tried multiple ports, but all I ever get is zeroes, no IP, but the router works fine, I'm connected to it right now. Everything else thats...
The best way to have this printer work is to connect it with an lan cable. Here are some steps to check if the printer will work again.
Disconnect the lan cable from both ends. Make sure that the printer shows the blue solid light, Try to do the factory and network card reset. First turn off the printer by pressing he switch button on the right side. Press and hold the GO button while turning it on, then press go button 8 times as fast as you can without delay. Once you see the blue light solid again turn off the printer and do the network card reset. Turn off the printer by pressing the switch button on the right side. Press and hold the GO button while turning it on, then press go button 7 times as fast as you can without delay. After 1 minute reconnect the lan cable from the router to the printer. Wait 1 minute again the press the GO button 3 times without delay, it should printer the printer setting page that shows the correct IP address.
Hope this will help.
Feb 27, 2011 | Brother HL-2170W Laser Printer
Lately, the sound/signal fades to nothing a few seconds after I begin using. I've changed batteries so thats not the issue. Dunno if its time to chuck it or now, about a year old.
The fact that signal fades is indicative of something with a time delay. The question is where the delay is. If your guitar has a preamp and this device due to wear or contamination on the plug breaks the battery connection within the guitar, the problem could be a worn jack in the guitar that MAY work with your normal cable but not this Amplug due to slight size differences. Other problems could be corrosion on the battery connections in the Amplug. Sometimes headphone cables go bad so try those in another audio source and make sure they are solid. Sometimes these thing have real weak switches and the intial actio of turning it on momentarily connects the batterry, charging the internal filter capacitors which then bleed off... so try working the switch and see if it pops back on..
Jan 29, 2011 | Bass Vox Ap-bs Amplug Bass Headphone...
Rohan wants to cross a railway crossing which remains closed for 5 minutes and open for 4 minutes. How much delay can be expected if Rohan reaches the junction at any random time uniformly distributed over...
Rohan arrives 1 second too late, and waits 299 seconds.
Rohan arrives 2 seconds too late, and waits 298 seconds.
Rohan arrives 298 seconds too late, and waits 2 seconds.
Rohan arrives 299 seconds too late, and waits 1 second.
Rohan arrives 300 seconds too late, and waits 0 seconds.
Rohan arrives 301 seconds too late, and waits 0 seconds.
Rohan arrives 302 seconds too late, and waits 0 seconds.
Rohan arrives 539 seconds too late, and waits 0 seconds.
Rohan arrives 540 seconds too late, and waits 0 seconds.
So, add the 299 different delays (299, 298, ... , 1)
to the 241 non-delays, and divide by 540 seconds,
to compute an "average" wait-time.
Sep 25, 2010 | Computers & Internet
Delayed brake lights
Hi bkleyn,
You can adjust the brake light time at the brake light switch, which you will find just over the brake pedal. By adjusting this switch away from the striker plate on the pedal, you will bring on the brake lights earlier.
Hope this helps you
John
Aug 30, 2009 | 1990 Volkswagen Fox
How to reset 5 minute blower delay for carrier 4 ton central system-instlalled 1995
There are potentially 3 time delay relays in this system.
1) Many digital Thermostats come with compressor ON delays that are not serviceable.
2) There is an accesory manual Time delay available for this unit. It is also a compressor ON delay. (located in the electrical compartment of the condenser)
3) Most newer furnaces have a blower OFF delay (set manually at the circuit board.
I have the technical manual for this unit if you need it.
Jun 25, 2008 | Carrier 38CKC042 Air Conditioner
29 people viewed this question
jasbo
jasbo
