Question about Janome MyLock 644D
I have lost my instruction manual - how do I move the lever to the rolled hem position? Many Thanks, Kim
  • 340 Answers
Http://www.janome.com/documents/File/ManualFile/MyLock644D.pdf
Here's a partial manual. I don't think it contains any info on rolled hems though, sorry!
Posted on Sep 02, 2010
  • hazelgrace
    hazelgrace Sep 02, 2010
    The Janome website has A FAQ section and you can submit questions to Jan as well as having a forum. YOu may find someone who can answer your question there. http://www.janome.com/index.cfm/Learning...
How to do a roll seam
Consult your owner's manual for instructions. You should probably have a rolled hem presser foot to make a rolled seam.
For basic instructions, search the internet for:
rolled hem
Nov 18, 2016 | Sewing Machines
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
Need settings for Simplicity easyLock SL370 rolled hem. Machine belongs to a friend who recently moved and the instruction manual has gone missing. Thank you!
narrow 3thread seam, so remove left needle. loosen top looper tension to 3 or 2, tighten bottom looper tension to 7 or 8. thread top looper with woolly overlock thread and reduce stitch length. there is also a thread finger u need to flick back on throat or needle plate usually to make rolled hem. also move blade to right to trim less fabric as you want the fabtic to roll under inside the seam.
Apr 28, 2011 | Simplicity SL370 Mechanical Sewing Machine
Rolled hem settings
Here is a link to purchase your instruction manual:
Pfaff Sewing Machine Instruction Manuals
Jan 06, 2009 | PfaFF Hobby 4260
How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
Jan 05, 2009 | Baby Lock BL1556
Needle Plate adjustment
ABSOLUTELY !!
R = Rolled
You will need to move the Upper knife blade out of the way, adjust S to R then restore blade to original position.
You have not mentioned Make or Model, so I will stab at the method........from the left of the machine inside the door you will see a knurled knob to adjust the width of the cutting........if you push it to the right, it will move the blade.......rotate it 90 degrees out of the way, move the chaining finger to R, put the knife back....... et voila
Where is your instruction manual ????????
If the knife mechanism works in a slightly different way, the principle is the same. www.bargainbox.com.au
Nov 24, 2008 | Sewing Machines
Instructions
There are rolled hem instruction sin the manual. You can download a copy of it directly off their website here.
http://www.feiyueusa.com/Manual/FN14U4AD.pdf
Jun 28, 2008 | Yamata FY14U4AD
Rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Jun 11, 2008 | Janome MyLock 634D Mechanical Sewing...
Ezy_Lock 304D
This may be too small to read, if so, email via
www.bargainbox.com.au and I shall send it on........remember to only ever use the R needle, so you only have 3 threads.
To move the Rolled hem arm, you will need to release the upper knife (knob on left inside cover....push to the right and blade moves approx 6mm) so you can slide the small metal tongue to correct position for:
N = Normal
R = Rolled
Jul 10, 2007 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 644D Logo
242 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
