I have a Whirlpool Cabrio model WFW6200S that we've had for a few years. It hardly ever gets through a load without stopping (frequently) with an "unbalanced load" error. It doesn't seem to matter what size load we have in it. It happens during the spin cycle generally. I've researched on the web and haven't found a consistent answer. Just wondering where to start on this. Any help will be much appreciated.
  • 1 more comment
  • bill622 Aug 29, 2010
    Thanks LocalWonder - I will try that!
    Yes, if you can send me the service manual that will be great. Much appreciated
    Oops - forgot my email - it is bill@billjill.org
  • bill622 Sep 05, 2010
    Just wanted to let you know that your solution worked like a charm. I installed the new suspension rods and now the unbalanaced load issue is resolved!
    I will say that the part that was the hardest to do, unexpectedly so, was getting the basket out. That took me forever. I finally needed my wife and two of my children to help me get it out. I guess trying to lift it out myself put a weird angle on it.
    Thanks again - you were very helpful. Much appreciated!
  • 6,784 Answers
HI. uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalanced the load.The display should clear if the mini-cycle can successfully re balance the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the user to view and redistribute the load. With that said; If you are overloading the unit consistently, you should expect this code regular to appear. This unit is not a super capacity unit. it is a middle non heavy duty unit that can be damaged if overloaded on the regular. Large king size comforters will cause the uL code to appear, as well.
Additionally, large or over capacity loads will ware down the internal balancing assembly and cause a very limp state in the suspension devices,thus, inducing an uncontrollable wobble during the spin cycle. if this is the case; the entire balancing assembly will need to be replaced to correct the balanced nature of the suspension assembly. Weak suspension assembly parts will trigger the uL code every time the unit spins on any load size.
The necessary actions are to install a new suspension rod kit. The part number for this replacement kit will be W10189077. If the unit wobbles even on a small load, this kit will be necessary. If you need a service manul to help with the replacement procedure, kindly, post your e mail and I will send it to your box, via, attachment.
Posted on Aug 28, 2010
  • 1 more comment
  • Michael Masters
    Michael Masters Aug 29, 2010
    The service manual has been sent to the posted e mail box. Let me know if it doesn't arrive.
  • Michael Masters
    Ok, The manual seems to be too large for e mail transfer. I will post a live link below to the actual manual so that you can download it directly to your browser. Once the manual is fully downloaded; You can save it on your HD for safe keeping. The manual will take up to 10 minutes to fully download. Please allow time for the large PDF to download to your browser, fully.
    Whirlpool Cabrio Service/repair manual link.
  • Michael Masters
    Michael Masters Sep 05, 2010
    That is great news. I am glad your unit is running at optimal performance once more. Great job on that repair procedure:)
    Bravo!
Washing times are getting longer
It might be easy. The hoses have screen filters at the end where they connect to the water supply. I mostly use COLD only so the cold one gets really clogged quickly. I bought a few at the HW store and I replace them about annually and the time drops like ten minutes or more. However, this year, after 12 years (I have an older model) it stopped helping. I ordered a new solenoid. The time plummeted from 80 minutes to 35. It was amazing.
Nov 19, 2015 | Whirlpool 4.6 cu. ft. Cabrio Platinum Top...
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio W10106480A keeps giving Unbalanced Load message and tub bumps the sides very hard and loudly
follow this step and fix it. God bless you
Washing machines are complex and have many functional components. It's always best to stop an unbalanced load, rearrange it, and re-start the washer.
Oct 01, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Hello~ We've been struggling to repair our Whirlpool Cabrio washer - Model - WTW6600SW2. We received the codes F50, F72 and just F - we replaced the stator motor and RPS sensor kit; however, we are...
Hi
Please check this list of codes in whirlpool cabrio.You will get a detailed idea about code F 50 and the test to be performed:-
http://www.appliancepartsquick.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our laundry smells moldy since we bought cabrio several months ago. We've done everything we know to fix problem ,, but are not happy with the service of this machine or smell of our clothes at all!!
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
Jul 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
