Question about Vacuums
How do you reset a pro series safe is not working and the keys are not as well, what can I do to get into the safe?
Operating instruffians for the pro heat 2x
click manual you want
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines
Here is a Troubleshooting Guide
Here is the Service Center Repair Guide
Oct 31, 2017 | Vacuums
Pro heat 2X revolution
Here is the Instruction or User Manual for the 9500 series machines..
Aug 16, 2017 | Vacuums
Pro heat 2X instructions
Manual for a Bissel pro heat
Aug 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
CATHEDRAL ELECTRONIC SAFE 25EA CANNOT OPEN IT WITH MY CODE NEED THE RESET CODE
You can't, as there is no reset code available once the door is locked. It would be absolutely useless anyway if all a thief had to do was to ask on a public website for a bypass code. The only alternative way into the safe is via the override key (an actual physical key which fits into an opening hidden behind a removable plastic panel on the safe door).
If you cannot find the emergency key then you have just one fix: you must open the safe destructively. Fortunately, your model is just a budget-priced electronic strong-box rather than a true safe, so the top or sides can be easily be cut open using a grinding disc or by just drilling a few holes and joining them up with a cold chisel.
Note that it's not worth calling out a locksmith, they'll only cut the box open and the charge will be many time more than the cost of a complete replacement strong-box (you can buy a similar complete replacement for under £40 including postage from this seller).
Sep 19, 2011 | Vacuums
I have a micromark electronic safe at home but the battery is low therefore it woun't let me open the safe and i don't have the key
hi.
without the key, your options are very limited.
apart from destructive drilling, or expensive locksmith charges there may be one chance.
place a fan heater, or similar heater in front of the safe for 3-4 hours until the safe is warm to touch.
be careful not to cause a fire risk around the safe, or to overheat the safe. DO NOT leave unattended.
it will take this time for the heat to be slowly transferred to the battery compartment on th einside of the door, but when the batteries warm up, you may find they have a slight boost from the heat, and actually have enough power to open the safe.
there are no guarantees that this technique will work on your safe, as it is very dependent on the amout of life left in the batteries, but is worth a try as a last attempt before expensive drilling or locksmith charges.
good luck
Jun 09, 2011 | Vacuums
Gordon floor safe sku# S91006 forgot my code can we reset?
Nope. They do it that way on purpose. If you contact Gordon with serial number and proof of purchase, they may have a work around. I would not count on it, though. Farmerbear at FixYa.com
Sep 30, 2010 | Vacuums
Is it safe to use shark steam Pocket Mop on Armstrong Vinyl no wax floors?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Yes, you can use it it will not hurt that floor...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Jan 11, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
170 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
