Question about Xerox Phaser 8500/DN Printer
Phaser 8550DN Blurred output inter mitently. More like the first page then the rest that follow are ok. Text looks like a shadow or an echo effect.
    Genius:
  • 1,224 Answers
Dirty or sitting ink left on paper feed and ink cartridges makin first pages blured
try to clean with little rubbing alcohol
Posted on May 07, 2008
    President:
  • 2,072 Answers
The encoder on the end of the drum assembly is contaminated with the lubricant from the maintenance kit.
You need to remove the right side cover, looking from the front. Look at the end of the drum, there will be an assambly about an inch and a half to 2 inches square with a couple of wires running into it.
That needs to be cleaned thoroughly with alcohol. It is contaminated and will cause the drum to run at the wrong speed.
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Toshiba 46XV645U Shadow Effect Problem
thats usually caused by a flex tab bond on the panel itself especially if the screen appears slow motion in that area.
Aug 07, 2012 | Toshiba 46XV645U LCD TV
Inter mitent wipper 2002 chev truck not working
Keven,
Thank you for asking me to help you with your problem. However, this is either not within my area of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 13, 2011 | Cars & Trucks
Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Zebra xi III Plus printing shadows and blurred text on labels. Initial printing was fine but all prints now have a shadow and blurred text.
Try adjusting your printhead. If that doesn't work you might need to replace.
Please contact me if you have any question or if you come across needing a printhead for your unit.
I carry all parts for that printer in stock .
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 01, 2009 | Zebra 110Xi III Plus Thermal Printer
Phaser 8500N Text looks like a shadow or an echo effect
there is an encoder on the end of the drum drive shaft. located on the right frame of the machine.
It becomes contaminated with the silicon lubricant from the maintenance kit, and off the rotating drum.
You remove the power from the machine, remove the encoder, and flush it thoroughly with alcohol. Then give it time to dry well, and put it back on the shaft. That WILL correct that problem. It is possible the encoder is bad, but I really do not suspect that because your problem is intermittent. But that is your problem, I guarantee it.
Jun 01, 2009 | Xerox Phaser 8500/DN Printer
I HAVE A XEROX 8560 THAT I AM GETTING BLURRED PRINT WITH, I DID THE CLEANING CYCLE AND THAT WORKED FOR A DAY AND A HALF. NOW THE FIRST TWO PAGES LOOK GOOD AND ALL THE REST ARE BLURRED?
Oil from the drum has ran off over the drum encoder position sensor.
Take the right cover off and find the fan. Remove it and loosen the clear plastic sensor cover underneatch. Clean the sensor and generally with Isopropyl and Q-tip.
Clean the nearby wires and anything that might be transporting more oil back to your sensor
Apr 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
My copies and prints are blurred with shadows
That was the Solution that the ink cartridge required a replacement
Aug 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
How to get echo effects
try putting the bass down
Oct 08, 2007 | Audio Players & Recorders
Xerox Phaser  8500/DN Printer Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
