Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Hi my hard drive turns on and everything , but for some reason it does not want to come up on the computer. it dosen't show that it is connected.
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Posted on Aug 29, 2010
Sony bravia hard drive
It appears (from your test) that the hard drive is not the problem.
It's likely your computer doesn't have the driver to this hard drive, or lost it (for ?? reason). Have you gone through the device connection tests ? or tried to locate, download and re-install the hard drive driver to your PC ?
Feb 15, 2014 | Computers & Internet
My hard drive dosen't show up on my desk top when i plug it in. What should i do? thx
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this format recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/adr/
Aug 31, 2011 | LaCie Big Disk 500 GB Hard Drive
Computer dosen't turn on. i ran the hard disk test it says "hard disk not exist"
There could be two possible problems here: A bad cable or a bad hard drive.
If you have a desktop computer, you could try swapping the cables over from your CD drive with your hard drive.
Failing that you need to get a replacement hard drive.
If you have a desktop computer, you need to check the connections on the existing drive or motherboard to see if you have a ribbon cable that connects to the drive and the drive has lots of pins to connect it, (IDE or PATA) or a narrow red or yellow (SATA) cable. You will need to get a 3.5" hard drive.
If you have a laptop computer, you also need to check the connections on the existing drive, if it has pins (IDE or PATA) 2.5" drive or if it has L shaped connections (SATA)
You will also need to reinstall the operating system from its installation CDs or backup disks. If you don't have them, you will need to obtain them from your manufacturer.
Jul 22, 2011 | Computers & Internet
Bought a new computer desk, shut computer down correctly, turned off all power and moved. Plugged everything back in, powered up - and everything but the iOmega Select Hard Drive is working. - It has...
Since it doesn't show up in both pc's then the iOmega is faulty - it must have suffered a shock during transfer and this is terminal. Your only hope of recovering what's in it is to dismantle it, take out the hard disk and put it in the desktop - if even there it doesn't show up then it's dead, junk it.
Sep 12, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have 3 maxtor 3200 storage units. A few days ago my computer would not start up so after unpluging the 3200 and everything else I got the computer to work again. Plugging in the mouse,keyboard,zip drive...
could be a software issue could be that the when you unpluged them you didnt unmount the drives from the system and now windows is not finding them for this reason the best way to "try" to fix this issue is to plug them in one at a time go into device manager and uninstall them from the computer then turn the computer off unplug the drive turn the computer back on without the unit pluged in turn the computer off again plug the unit in restart the computer this will work on 75% of the drives that can't be seen
Jan 25, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a 120GB external hard drive. it's saying that i have 111.78GB used and only 3.4GB remaining available. this is IMPOSSIBLE. for many reasons, but mostly because no matter what i do - including...
Thanks for using FixYa!
What you need to do is to format your hard drive. Go to "My computer" right click the hard drive.. then select format. Do not use the quick format procedure. This should solve your problem.
Have a nice day.
- HotRatchet
Aug 01, 2009 | LaCie 120GB Little Disk USB2/FW400 120 GB...
Hi I have an exterbnal hard drive which for some reason is no longer showing up on my pc It doesnt show in device manager either. Atcually they are 3 external MAXTOR hard drives that have the same...
Hi
first you chake the jhumper settng in your available hard drive. make sure the jhumper are diffrent way attached in all three hard drive. for e.g. :::i , ::i: , :i::: . in that way you will arrange your jhumper in hard drive.
I sure the hard drive is show in device manager
Thank you
Jan 06, 2009 | Computers & Internet
WD Notebook Essential 80G just quit working
if you are not getting any broken noise from the hard disk its not ded so ushut down the computer first then connect the hard disk to the power and then connect the hard disk to your system in the usb 2 port then connect the start the system if still dosent detect go to manage by right clicking on the my computer icon the go to disk management check your hard disk shows ther if shows forign just right click on the forigen and say import forigen hard disk if shows the drive helthy and dosent show up on my computer then just right click on the helthy place and say change drive letters and choose one of the letters and should show up on the my computer if still dosent see at all then change the usb cable....
if still dosent work remove hard drive from the external case and put it directly to your computer for this u need a sata cable and a sata power if it detects and work this way your data is safe but you casing of the external hard drive has probs ...
thanks
Nov 12, 2008 | Western Digital 320GB MyBook External USB...
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Connection issue
reboot the pc, also try a different usb port.
Dec 11, 2007 | Computers & Internet
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
53 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
