Question about Polk Audio EX12 Car Speaker
SUBS i have two 1200 watt KICKER CVR subs connected to a 1200 watt amp. the wires are somewhat thin and every time i turn the volume up close to MAX on my stereo the subs cut off. do i need a stronger amp or thicker wiring??
    Genius:
  • 1,224 Answers
The bigger the wire the better the resistance but even a wire wont do much
the only thick i have on my sterio is the battery wire the rest is cut old extension cord wires and mine sound fine never cut out on me and i have 1600 watts going threw amp
more power putting threw the hotter the amp hotter the amp more the cut off amp
quite possible you have too much power going to speakers if your bridged it will blow out amp found that out from bridgeing but thank god i had it fused
turn down your gain and bass boost and work up to good sound say your sterio is 1-60 volume your should hit right around 30 volume by turning gain and boost untill quality sound this is your safe zone gain should be set 1/2 volume of sterio to 3/4 pushing it nothing more or total melt down
Posted on May 07, 2008
    Master:
  • 619 Answers
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Jun 07, 2009 | Kicker CVR12 Car Subwoofer
What would be the best amp to run two kicker cvr 12 12" subs. would i need a second battery?
Do not buy a second battery without first upgrading your alternator and wiring for the added draw. Adding another battery will make the already stressed alternator work even harder. Find an amp that has sufficient wattage to drive both subs at rms. If your subs are each rated at 600w rms then look for a 1200-1400 watt amp. Good brands are a dime a dozen these days and you don't necessarily need a kicker amp. If you wish to upgrade alternators i would suggest searching for OhioGen or Ohio Generator. .They make alternators for high current demanding systems and multiple alternator system solutions. As for amps look at names that have been around for a while like Mbquart,Soundstream (older stuff like rubicons...) ORION (older HCCA models are great) and such.
May 02, 2009 | Car Audio & Video
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Polk Audio EX12 Car Speaker Logo
190 people viewed this question
Top Polk Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Polk Audio Car Audio and Video Expert? Answer questions, earn points and help others
