Question about GE JVM1850 1000 Watts Microwave Oven
The timer was set without anything in the Microwave. Now nothing is workiing - no lights, power, etc. It was very hot!
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 29, 2010
Kenmore 62463 / 721.62463201 Stainless Steel 1200 Watts Microwave. My daughter used it as a timer for reading and set it to cook for 30 minutes with nothing in it. It turns on but is loud and no longer...
You probably fried the magnetron(it actually makes the microwaves that do the cooking). I bet you will find the magnet is broken(from excessive heat). There should be a diagnostic guide sheet somewhere inside the housing(due to running production changes,this is a guide for the pros to test the power supply,magnetron,etc with an ohmmeter to determine which is defective.
Sep 18, 2013 | Kenmore 62463 721.62463201 Stainless Steel...
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
My GE Spacesaver microwave is not working...no power at all.
Usually a Thermal protection (Like Circuit Breaker) this should be tested with Multi Tester. If this open, no Electrical Power goes to the Primary Winding of your High Voltage Transformer and will not power up your magnetron therefore no heat inside the Microwave Oven.
Jul 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
Above Range GE Microwave not heating
Try disconnecting the power line from the microwave ad then reinstalling it after a few minutes.. then try heating up a small cup of water.. allow 1.5 minutes on high power. it should get very hot or boil.. if it doesn't get warm or hot then you may have a bad magnetron ( the tube that produces the microwave energy that causes things to heat up or a bad filament transformer that is required for the magnetron to work.In either case, if it fails to heat anything, I would go back to home depot and insist they send someone out to address the problem. many of their appliances come with a one year warranty but you might want to call the store and ask someone there about normal applaince coverage ( less extended warranty) and what they normally offer. An inquiry costs nothing..
Hope this helps..
Sep 17, 2008 | GE Microwave Ovens
GE JVM1850 1000 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
