Question about Craftsman Garden
How to reconnect gas lines on sears 358.795160
    President:
  • Craftsman Master
  • 1,545 Answers
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Posted on Aug 29, 2010
Pilot will not lite
disconnect pilot line at gas valve if gas there then pilot line or pilot orifice is plugged clear with compressed air reconnect and try again
Nov 08, 2013 | Cozy Enclosed Front Console Heater 70,000...
Tractor runs only when choke is pulled
A gas engine runs on a mixture of gas and air. Too much air, not enough fuel, and you have to decrease air to maintain balance.... Many things could cause this, clogged fuel filter, gas cap not venting, old/defective gas line, dirty carburetor.... If "popping" is involved, there is too much water in the gas.
Apr 13, 2012 | Sears Garden
I have an 18hp 42inch cut Sears Craftsman, it will
You might want to checked your fuel line coming from the tank,sometime it will collaspe inside the line and not allow enough gas to get to the engine.
May 15, 2010 | Garden
Gas trimmer - not getting gas
the primer bulb needs to be replaced, if it has a small hole in it
Sep 09, 2009 | Garden
Gas line needs to go thru buttom of gas tank on sears weed wacker
Take your old line to a lawn mower parts store, ask for a new gas line of the same size. I would buy about a foot long. Push the line in the tank down into the tank(doing this with the tank empty), remove gas cap, turn upside down, a filter and your old line will fall out. Press the new gas line through the hole, push enough through that it comes out of the filler hole, place filter onto the new line, drop into tank, cut off excess and reattach to the carburator.
Aug 06, 2009 | Craftsman 25cc Gas Line Trimmer
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
One of the gas lines came loose and it is not clear where to reconnect it.
The shortest and sometimes largest of the two goes to the primer bulb. The other goes to the carb.
Jim
May 31, 2009 | Yard Machines Garden
Gas lines on Poulan Pro model 112
i need a diagram or manual for a sears craftsman weed eater so i can put new
gas lines on it
Sep 06, 2008 | Craftsman 25cc Gas Line Trimmer
Garden Logo
369 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
