Can,t find where 2 get weatherking electric furnace parts
    President:
  • 3,074 Answers
I have no ideal where you live but Bakers Distributors can order parts and I am sure if you look in your area whomever repairs sells service and parts can order them.also. Hope this helps tim
Posted on Aug 29, 2010
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
My weatherking furnace shuts off, i can hear clicking from the gas relay, but don't know if it is the relay or the pressure switch. when i reset the power it comes on again.
weatherking furance shuts off, i can hear a clicking noise from the gas relay, dont know if its the relay,pressureswitch or gas valve.
Dec 27, 2009 | Heating & Cooling
Weatherking WRKA heat not working control board
U need to supply more info.There will be a sticker on the furnace likely in the lower Fan Compartment which will have a legend that explains each error code...ie: 3 blinks = Pressure switch etc....and u will need to provide more info on how the furnace is operating (whats it doing ) when it stops working or just prior to that
Oct 16, 2009 | Heating & Cooling
Igniter keeps breaking
Wow, this is a new one on me! Are you using true OEM parts for your source? If not, you may be getting sub standard parts. There are some companies that use generic parts and this isn't a good thing to do sometimes. Weatherking is a Rheem/Ruud product.
Apr 10, 2009 | Weather King 12AJA4801AH Air Conditioner
KING FURNACE MANUAL
You do not need a warranty card for your warranty to be valid. Your installing contractor provides the labor warranty and the factory provides the warranty on parts. All the necessary information to make a (parts) warranty claim is embedded in the serial number of your unit. As for a manual you should contact the installing company or visit the Weatherking (Rheem) site to request this information. www.weatherking.com
Mar 26, 2009 | Weather King 12AJA4801AH Air Conditioner
Weatherking Short Cycling
You make a good point about overheating on heat exchanger temp.
Since you don't have to reset anything for it to recycle, then I assume you have one of the newer forced draft furnaces.
There should be leds on the control board inside the furnace compartment that will blink a code to you, telling what the shutdown reason was. Blinks and code should be on a label inside the blower door panel, or inside the control box cover.
Let me know what they are, and I can give you more direction. I am assuming this furnace worked at some point, and no changes have been made (including closing of duct vents).
Jan 26, 2009 | Kitchen Appliances - Others
WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
