Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Asus Router Offline
my router Asus remains offline when I branch. All LEDs are extinguished.
Changing a fuse, maybe ?
Could you help me ?
i connect the routers wan port with the modem but i cant conect to the internet wirelessly
    Novelist:
  • 144 Answers
Hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Posted on May 08, 2008
How do I get out of offline
Hi Murd, to get out of offline, you have to be online. That means you need to connect to a form of internet. This could be as simple as turning on your wifi on your device. Once your wifi is on, you need to connect to a router. A list usually shows up when you turn on your wifi. Choose your internet router connection, make sure it shows its connected, then try again to see if your still considered offline.
Apr 19, 2016 | Android Huawei
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
Cannot connect internet as it shows internet is offline
Always check your LAN cable between your modem and the router and try a new cable. Login the make certain your router is configured correctly to connect to your mode.
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Router page not available offline
You don't connect to WAN port, you need to connect it to one of the switch ports. The wan is strictly for modem configuration
Dec 17, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Just got dlink router and it appears to be connected right just says no internet connection found and I dont know how to change it It is for a laptop just always says I am offline however it installed and...
Launch your Internet Explore browser goto FILE>Work Offline if that is checked your browser is working Offline mode, just uncheck that, and hit refresh you should be good to go.
-Charlie S.
Jul 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Losing connection
When the phone is ringing or in use, it is interupting the router signal. You should be able to avoid any interference with your router by changing the channel on your phone. If that doesn't help, you'll have to go thru the router setting and change the channel on the router. Try the phone though, thats the easiest fix. Good Luck to you!
Oct 14, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless connection but internet is offline
There may be another program intersecting with your program make sure that in your start up you only have the program that you want to be your networking program.
Oct 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help
One solution might be to go into the file menu of Internet Explorer and de-selecting "work offline".
May 12, 2008 | Belkin (F5D7230-4) Router (587009)
Deafualt gateway appears offline
hi srini here
The site could have been blocked in the router.
Check it out.
Apr 05, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
