Question about GE 24 in. GSD4030Z Built-in Dishwasher
Water will not drain power light flashes - GE 24 in. GSD4030Z Built-in Dishwasher
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Flashing 5E
You have a "water drain" error. It may be clogged with ice or debris. http://appliancehelponline.com/samsung.html
The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Oct 03, 2014 | Samsung Refrigerators
Hoover VHD842- About 10 mins into the wash, the washer stopped and the 'timer saver' light and 1200 spin speed lights start flashing at the same time, approximately flashes five times then goes blank, then...
I'm interested in how you manage to drain the water away- is it by the filter cover? If not may I suggest carrying out the following- if you have not done so already ;-0)
(If you have -sorry. This will not help)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 26, 2011 | Hoover Washing Machines
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Wil163 3 lights flash mid wash
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Apr 12, 2009 | Indesit WA 115 Front Load Washer
Problem with wt540
Have you actually tried to pump water out, if you select a drain only position or drain and spin ,and hold the drain hose into a bucket or into the sink, you should see water pump out.
If it does not ,then you have a blockage somewhere, or your pump is faulty, assuming of course that the pump is getting power.
Plz leave feedback.
Ta
Dec 10, 2008 | Washing Machines
ZDT5052 flashes quickwash light
Tarvi...I don't know what the problem is...hard to diagnose these things. If the unit is working correctly, I suggest that you simply cut the power for a few minutes and then restart it. That may clear our a trouble code.
Dec 06, 2007 | Zanussi 18 in. ZDT5052 Slim-Line Built-in...
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
