Question about Coleman Mach 15 Air Conditioner
Water leaking from A/C
When it rains I get a lot of water leaking thru the ceiling around the air conditioner. Is there some sort of seal that is failing here and how would I go about replacing it?
    Genius:
  • 1,224 Answers
Ok this unit should have a silicone seal around the pan so water does not collect under it if old silicone is worn away scrape old silicone away and redo new silicone around unit so it sits properly make sure all the water is gone before sealing because you run the risk of mold build up under it; let it dry or help it dry thats up to you
but would like little more info on what this is on
Posted on May 07, 2008
How to stop water from coming in the passenger floor board
That depends upon the cause of the water. There are a few possibilities, depending upon the vehicle. See this list and use what applies as a way to narrow down the source.
1. Rust hole in floorboard. Only way to fix is to repair hole.
2. Leaking door seal on passenger side. Locate and repair leaking seal.
3. Leaking sun/moon roof. Some vehicles that have these run their drain lines down the passenger side door pillar and down thru the floor pan. Sometimes the hose shrinks with age or breaks and allow water to get on to the floor. Remove the passenger side kick panel and inspect and repair as needed.
4. Leaking heater core. Feel and smell the water. If it smells like antifreeze or has an oily feel, it may be coolant leaking from the heater core. Of course there should be a loss of coolant associated with this problem. Here the only solution is to bypass or replace the heater core.
5. Leaking windshield seal. Most car windshields today are glued into place. These glue joints can break loose and allow water to leak. Also, rust can form around the windshield seal and cause rust holes that can leak. Lastly, extremely high-powered car stereo systems that pump mega-bass can cause overpressure inside the vehicle that can cause the seal of the glass to separate.
Jan 31, 2016 | Cars & Trucks
Ceiling leaks
coil is dirty or frezing up allowing water to leak.
Jul 07, 2013 | Ruud UBHC Air Conditioner
Our penquin dometic air conditioner in the bedroom pours leaks lots of water when the unit is on during rain storms. Water leaks into the ceiling and also out the unit.
Sounds like base gasket at roof is loose or defective to start with. Try removing ceiling assembly enough to tighten 4 bolts that secure roof unit to inside bracket. Do not compress too much, just snug them all evenly and see if water slows or stops. If not, you will have to remove upper unit (roof) and replace gasket and re-secure but don't tighten to excessive, only compress gasket approx half of original thickness. Also make sure upper unit is aligned properly with opening of roof.
Sep 23, 2011 | Dometic Rooftop RV Air Conditioner
Water on floor passenger side after it rains and after air has been running 2000 grand prix
Ac hose leak?
leaking heater core?
Hint: it leaks when it RAINS
If it were related to the heater core or the AC drain, it would be leaking when it is not raining also, so those diagnoses are not logical.
The grand prix has a long history of floor leaks from seal failures around the air intake under the windshield cowling, where RAIN water runs in.
May 04, 2011 | 2000 Pontiac Grand Prix
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
I suspect water is seeping in under my AC unit...
The roof A/C unit has a foam rubber seal/one piece gasket that fits around the part you see inside the coach but must be put in pklace before the unit is inserted in the roof opening. Replacing is relatively easy but you will need to remove the interior trim Disconnect the wiring from the coach to the unit and remove the four bolts holding the unit in place. Then lift out the A/C.to replace the seal. They do leak because of age and compression by units weight. Good Luck
Jan 28, 2010 | Dometic Rooftop RV Air Conditioner
My sunroof is leaking a lot onto the front seats. More after rain, but it still leaks for a few days after rain.
While its raining the water is running thru the seal, after the rain the seal shrinks.
Jan 18, 2010 | 1997 Hyundai Accent
Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Jun 18, 2009 | Heating & Cooling
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
Water leak
If you remove the air grill for the inside part you will find four screws which when tightened compress the seal gasket under the outside to roof. It may be a case of these screws being somewhat loose.
Apr 12, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
124 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
