Question about Haier HLF103Q Electric Dryer
No heat and motor won't turn. - Haier HLF103Q Electric Dryer
  • Haier Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
My mitsubishi galant temp control lever won't switch to heat
that happened to me the heater core went out ive read alot of different things about 03 galants most of them have the same problem it started with a grinding noise turning the temp contol, its actually the heater control motor value it causes the heater core to go out
Dec 27, 2012 | 2003 Mitsubishi Galant
Dryer turns on but drum won't turn
Remove the top to see if the belt is intact. If it is, you will need to replace the motor. Here is the motor to order.If the belt is broke, here is the belt to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 11, 2012 | Dryers
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
Okay 2001 ponitac Aztec We have two of them. This one I was turning the heat off and heard a click it sounded like something broke and Now the heat won't turn off at all! Please help with any sugg
Sounds like one of the blend doors stuck and-or the actuator motor broke. The blend doors direct air flow thru the heater core and the evaporator as well as out the vents. They are controlled by small electric motors.
Sep 28, 2012 | 2001 Pontiac Aztek
Dryer heats up but does not turn
Broken belt is the first thing to check. The motor must be turning or the heat won't come on
Oct 19, 2011 | Dryers
Plate won/t rotate no reheating
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor. for no heating please check fuse between high voltage transformer and high voltage capacitor. Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
Jul 29, 2007 | Whirlpool MH6141XK Microwave Oven
Haier HLF103Q Electric Dryer Logo
83 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
