Question about Music
Organ will not turn on. - Music
  • Music Master
  • 5,603 Answers
We can't even guess what make or model organ this is.
Posted on Aug 29, 2010
Does an organ have to be tuned to a piano?
Electronic organs typically do not require tuning
A pipe organ produces sound via hundreds or thousands of organ pipes, each of which produces a single pitch and timbre. The goal of tuning a pipe organ is to adjust the pitch of each pipe so that they all sound in tune with each other.
Feb 17, 2018 | New Music
KORG CX-3Combo Organ
DSP is Digital Signal Processor.\\
That is electronics and would have to be serviced by the company or authorized service centre
Sep 17, 2016 | Music
I believe organ hasn't been played or even turned on in over 10 years. The top keyboard plays if I turn on a setting such as piano or trumpet however I can't just get the organ keys to play.
Since the organ has not been used for a long time, I suspect that there can be degradation of the electronics, specially with electrolytic capacitors. hence I request you to switch on the Organ continuously and allow it to warm up, it there is improvement , then it will be worth to remove the bottom panel and clean up the boards,dry the PCB with a hair dryer and reconnect the boards.
Hope this will help.
Jan 23, 2016 | Music
How long before the alarm goes off after Baldwin 210 Model Organ has been left on?
There is not an alarm in the organ. Some internal part overheated and either failed or openned a circuit. If when it was turned off and cooled down the noise stopped, it will return but there's no way to predict when. You need to call a local serviceman to check it ut.
Nov 13, 2015 | Music
How can I turn off the sound to the foot pedals of my Lowery organ. Is there any setting on the organ to do that?
If you turn off any voice tabs for the pedals, they are effectivly turned off.
Mar 22, 2015 | Music
Can I ship an organ on it's back?
Depends on the make and model. A all electronic organ with very little mechanical components should be fine. The older Hammond organs do not like to be tilted to far of the vertical. What make do you have?
Dec 21, 2013 | Music
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
Need a fuse for a lowrey-genie organ-44
If the fuse blew, it is for a reason. Probably shorted filter capacitors.
Oct 13, 2009 | Boss Micro BR Digital Recorder
Music Logo
21 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
