Question about Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEW0050PQ doesn't heat up
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 29, 2010
SOURCE: How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Posted on May 15, 2009
  • 415 Answers
SOURCE: whirlpool dryer model LGR6611LQ0 will not heat up
check for tripped breaker and proper voltage, next check to see if turns on if your getting air to the outside vent if ok the you need to open the unit up (unplug it FIRST) your be looking for the thermal fuse and or the cutoffs these will be attached to the blower housing assy ohm them out and also if electrical one check the heating element as well most cases this will solve your problems
Posted on Aug 21, 2009
  • 396 Answers
SOURCE: dryer runs, no heat Whirlpool duet 9250
Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on. The part should be about $25.00.
Posted on Feb 15, 2010
heatman101
  • 43501 Answers
SOURCE: Model # LEW0050PQ - The dryer heats and runs for
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 15, 2011
SOURCE: I bought a whirlpool dryer
Please we have same exact problem i pray for you if you kindly help us!
Posted on Oct 30, 2011
Re: LEW0050PQ The dryer does not power up. Is it a switch problem?
How new is the dryer? Is the door latching? Check the main electrical breaker for the dryer.
Feb 12, 2011 | Whirlpool LEW0050P Electric Dryer
Model # LEW0050PQ - The dryer heats and runs for designated cycle time, however does not spin. Will spin if you manyally "push start" it however will get stuck when cycle spin reverses. HELP!
Dryer Repair - The
Dryer Repair - The
heatman101
Jun 25, 2010 | Whirlpool LEW0050P Electric Dryer
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Greeting From Alaska. I have a dryer Model # LEW0050PQ S/N# CAR4502402 that will not heat. The first indication that there was a problem was that the dryer would not shut off when you open the door. It...
either your element is bad,also you could have the neutral wire on the element burned off which will leave you with 240volts across element,you do need the neutral to make elements heat also ckk for 120/240 volts at dryer
Jul 13, 2009 | Whirlpool LEW0050P Electric Dryer
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
417 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
