Question about Garden
I have a Makita DC18RA charger and the green and red lights alternately flash with a beeping. I have 4 batteries and not a single one works anymore.
  • 165 Answers
SOURCE: Brand new Makita DC18RA charger wont charge the batteries.
Return to store for replacement.
Posted on Feb 27, 2010
rowdy45176
  • 2176 Answers
SOURCE: red and green light flashes alternatingly with
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Posted on Aug 26, 2010
  • 885 Answers
SOURCE: HELLO: OUR MILWAUKEE 48-59-2401 BATTERY
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Posted on Jan 21, 2011
  • 827 Answers
SOURCE: My Husky battery charger does
You need new battery... they do **** out after so many uses and or time...
Ck
Posted on Feb 13, 2011
  • 1015 Answers
SOURCE: what does a red blinking
I would clean the contacts on the battery to be charged and the charger. You can do this with a discharged battery and the charger unplugged usins a small mechanics wire brush,they can be had made like a tooth brush and work well for tight places. Gently brush and then blow out with air. Make sure that battery is firmly seated in charger and if light continues to flash you probably need a new battery. Thank you.
Posted on Mar 07, 2011
DC18RA battery loader is not working anymore.
Makita chargers are designed to check a battery before charging them. If both the red and green lights are flashing after you put a battery on the charger, it is reading a problem with the battery and will not charge it. It could be a bad cell, a problem with the circuit board, etc. but as long as it reads the problem it will not charge the battery.
Jan 04, 2013 | Makita DC18RA Rapid Battery Charger For...
My dc18ra makita battery charger flashes red and green lights no matter how many bateries i try
The pcb inside the battery has a microcontroller that monitor the charges and charge cycle. When the cell falls below a certain voltage, it will instruct the charger not to charge and will show with a red-green flashing light. If the battery has been tried 3 times in succession then the pcb will brick itself from the makita charger. So first replace the bad cells. There are 2 solutions at this moment: charge with a 3rd party lithium charger like the imax b6 or replace the pcb with a working one. check out my blog on http://mkbl1830.blogspot.com/
Mar 17, 2012 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Red and green light flashing on 5 of my bl11830 battaries and they will not take a charge
If you put a battery on your charger and both red and green lights flash it is indicating that battery is defective. There may be a short in the battery or they just may be too old and worn out to charge anymore. If the charger is reading the battery as defective it will not charge the battery. The only fix is to buy new batteries.
Jan 20, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Hi both red and green lights are flashing and it wont charge battery bl1830 lith ion
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Sep 13, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
MAKITA LXT BATTERY CHARGER
hey
flashing orange=cooling abnormality.
you need to wait for the battery to cool.
see my mod page, it has all light explanations in it.
Have fun
Avi
Jan 09, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Garden Logo
303 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
