Question about GE (PSS26MSRSS) Side by Side Refrigerator
Condensation on inside of refrigerator and frozen water build up in one of the drawers. Fan makes loud humming sound as well.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
My refrigerator has a loud hum. what is the problem
A dirty motor fan could also be causing the problem, so check the fan or make sure it's not dirty, frozen, or stuck on another object. This loud humming could also occur when the fridge door is open for an extended amount of time, as ice will build up on the evaporation coil.
http://www.alesouk.com/
Jan 10, 2017 | Refrigerators
The fans have become very noisy what can I do?
there are 2 places to check....Not sure of the model of your fridge but on the backLook for the compressor fan...make sure it is clean and free of dirt...Alot of times there are located on the back but I have seen a couple older ones where the fan is located on the bottom....They get clogged with dust and dirt/....but for a noisy loud fan I suspect your fan inside the fridge is partially frozen...condensation collects around these fans alot and freezes ...the ice hitting and rubbing against the fan itself...so located the fan on the inside....It is usually towards the bottom and behind the little drawers...and hidden behind a sheild of some sort....defrost with a hairdryer if needed....good luck.
Mar 03, 2015 | Refrigerators
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/kevin_7bb01000e7ac403e
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Both the refrigerator and freezer are set to the recommended temperature, however, the refrig unit is making a loud humming sound. This sound stops when you open the door, but begins again when it is...
There is a fan that blows cold air into the refrigerator. It usually stops when the door is opened. Check to see if it might be frozen with ice if the humming sounds abnormally loud. Usually if it freezes up you cannot hear the fan running and the refrigerator will not get cold enough.
Aug 25, 2009 | Refrigerators
Refridgerator side not cooling. No air movement.
vent clear but vent opening arround vent frozen or coil is frozen eithor way you probably need a thermostat and a timer
Jul 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
Whirlpool Fridge Making a rattling noise
There are 2 areas it could be in....The upper area where the evaporator fan is....or the lower area where the condenser fan is..
If it is in the freezer...when you open the door there should be a button that the door connects with that you can hold in manually to make the fan engage..and listen for the noise..the odds are if it were ice build up....your thumping the fridge would not make it stop ..since the thumping would not remove the Ice...it would continue to build up and the fan would eventually stop completely and everything would warm up. It could be a loose stap that holds evaporator lines in place or a motor mount that is loose ..
Or it could have to do with the condenser fan..where the compressor is.The compressor and condenser coil are located underneath the freezer section of your refrigerator. There is some tubing connecting the compressor to the condenser coil. There is also a condenser fan to cool the condenser. To access these parts the refrigerator has to be pulled away from the wall. If you pull the refrigerator out go slowly and watch the tubing that connects from the water valve on the back of the refrigerator to the water cut off at the wall.
Remove the power from the refrigerator. Remove the lower panel on the rear of the refrigerator. Look inside for anything loose. Locate the condenser fan motor and blade. These are the areas to stay away from when power is applied. Plug the refrigerator back in being careful to avoid the condenser fan motor and blade. Wear gloves to prevent burning yourself on the hot refrigerant lines and try touching tubing and lightly pushing and pulling to see if you can cause or stop the noise.
Generally a rattle or hum is caused by a refrigerant line touching part of the cabinet or base pan. If it is not repaired it may rub a hole in the refrigerant line causing the refrigerant to leak out. If you don't feel comfortable trying to correct it, you should schedule service and let a technician repair the refrigerator.
I hope this helps...please rate me ...thanks The Fang
Mar 26, 2009 | Refrigerators
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
